Syck of Triple S' SC VIP/Drifter
#78
Glad to see more guys going the 1.5JZ route....nice job!
I have been a huge fan of the 1JZ head for a long time. Heck, anything made by Yamaha for a car is a blessing.
Youtube "Great White Supra" and see this 1.5JZ monster!!!!
What ecu do you plan on running with the 1.5JZ setup?
#79
1.5JZ VVT-i needed a Make Over!!!
Clean & Prep
First coat laid on thick 5mins in between each coat
After third coat
Wanted gold Toyota and VVTI under the CF going to cut out after it sets
After drying
Hot tanked heads masked off ready for paint
First coat of wrinkle black
After third coat
Cured at 200°F for an hour
After oven cure
Outcome afterwards
After third coat
After drying
After third coat
After oven cure
Outcome afterwards
#86
The piston domes aren't it... a vvti head needs the vvti bottom end for the oil feed line for the vvti solenoid on the head.
#88
I completely scrapped this idea
I wanted to start the full interior restoration and get that done before I worked my way to the exterior things but my shocks are going so I decided to focus on Stance and drive ability instead of waiting til the winter was over. Once I do that I'll finish the interior with racing seats and harnesses. I figured I could slide all winter and practice on the new setup and get a better idea of the new things that come with being lowered and fatter wheels. I won't really slide on dry ground until I get a LSD w/ solid bushings and a lighter driveshaft. I believe in footwork first before performance. Full suspension upgrade. I'm working from back to front. After that stage I'll begin the NA-t phase from bottom to top. Lighter flywheel and performance clutch, bearings, metal head gasket and ARP studs to handle the boost before it comes. Then a AEM V2
After all those are secure I'll get the CxRacing kit for the NA 2J and maybe 272 cams....aiming for 350hp on the street to 500hp for the track... I live about an hour from Englishtown NJ so I'll be hitting Clubloose and the East Coast Bash where Drift Alliance reign right now...
doing something UNIQUE instead
#89
Bussin' the work down
it took about an hour to disassemble and get the linkage right ... I used all (4) bodies from one unit and (2) bodies from the other
after being hot tanked 20 years off gunk removed
A clear before & after difference
