CD009 350Z 6spd On 1JZ SC400
#62
yeah, it definitely made it a ton easier. I was to the point of almost saying forget it, I will just let the trans pull the tunnel in when I tighten down the crossmember bolts. But I didn't like that because I didn't want any undo stress on the bellhousing bolts, and I want to make sure everything is centered and that the driveshaft is straight without undo stress. I am doing all of this on jackstands, and was getting uncomfortable with how hard I was having to pound under there. My whole underbody is rubberized under coated so my hammer was just bouncing off the tunnel.
This is BY FAR the way to go. You just have to make a platform of bricks to stand the jack on, otherwise as you pump the jack, the wheels on the jack will just make it want to roll down.
#63
Did a few things over the weekend. Nothing major. More thinking than anything else. I did decide to just make my shifter similar to what Ali_SC3 has done. My original intention was to use the first roll pinned linkage part on the shift rod, cut the top part off as Ali's was (see post #53), except bend the bottom one down 90 degrees, and then use the hole to mount a rod end pivot joint as shown in post #59. But, after removing the linkage part and cutting off the top one, the bottom would not bend down cleanly.
So, this is the direction I am taking:
240sx short shifter with housing, and a dual bend Integra shifter:
I wanted to remount the linkage as far up the rod as possible, so using a dremel, shaved back the welds on the linkage part and drill holes in the same exact location, except as close as possible to the linkage so that the linkage can be placed furthest up the shift rod as possible
Rod trimmed back (used angle grinder), and linkage reinstalled with roll pin. I cut the rod back a little too much, but still plenty of meat on it. I will have to open up the bottom hole on the linkage a tad bit more to be able push the roll pin all the way through
I will have to cut the black plate back so that it is not hanging over the inspection plate. Then, I will have to center and drill mounting holes so that it can mount to the existing holes on the tail of the trans. I will also shave back as much of that top radius above the brass piece that I can. That will get me a flatter, lower mount, and will also give me some more surface area for the plate to rest on and be supported. I will then have to open up the hole on the linkage a little more so that the plastic piece on the shifter can fit snug, then will JB weld it in place so that it can't come out. For the shifter itself, I will cut the the stock 240shifer back inside the housing, and also cut the integra shifter and drill and tap both for a hefty stud so that they can be connected together. That ought to get me right to stock SC location
Also, I think I am going to go a different route for clutch master cylinder. SupraStore has a Tilton clutch master cylinder upgrade kit for $360. It includes a 3/4" bore master (stock is 5/8"), and an adapter to adapt it to the clutch pedal and firewall mounting points. BUT, I'm not paying $360...
I will be going with one of these. Its a 3/4" bore Wilwood (part number 260-1304). It's like $50. Then, can just buy a piece round aluminum stock and drill a couple holes and tap a couple, and trim it to fit on firewall next to brake booster
#64
very nice, I forgot to mention that I drilled a hole forward of the original also on that brass piece, pretty much exactly what you did there, totally forgot I did that for an extra .5".
I remember I tried to drill the shift rod itself, and I couldn't even scratch it with the drill bits I had, its made of tough stuff. the brass piece is like butter to drill through though, and I wouldn't bend it much it will weaken and snap after a few bends.
Interesting with the integra shifter, I would still consider doing the v160 shifter for reverse lockout, and for the extra 2" just use a shifter plate of a gated auto shifter, it sits 2" further back than the stock manual shifter plate so you can use a straight shifter.
that is what I was going to do anyways. good luck and keep up the good work.
#65
#66
#68
yeah, once I get it working, I'm going to add what was done to the first page so that everything is all in one spot
#70
There are a few people that are having issues with the clutch which was resolved with upgrading the master cylinder. The cost of that upgraded Wilwood setup is less than an OEM SC master cylinder. So I might as well just do that, even though I already have a brand new in box Aisin... Guess will just sell that
#71
I just picked up a gated shifter on ebay for $70. I have been watching for them for the last few days, and just seen one today at a decent price. Funny because we were just talking about it. So, I guess I am going that route
#73
I am a little bit concerned here of how thick the V160 shifter is. Wondering if it will have enough room inside the 240 housing to hit all the gears?:
As far as the kit goes, it will come in 4 shipments. 1 from Collins which will include the bellhousing adapter, differential adapter, trans crossmember and hardware. Driveshaft will come from Shaftmasters, Flywheel will come Clutchmasters, and clutch kit will come from ACT.
I placed my order with Collins on 2/8. I received driveshaft on 2/16, Clutch and Collins stuff on 2/17, and flywheel on 2/18
#74
the fat part on the v160 shifter slides up and down, so just cut at the thin part of the rod and weld onto the 240sx shifter rod. unfortunately it has to be a cut and weld thing. good find on the gated shifter with the heated seat buttons, I have one stashed away in case I do this mod as well.
