Build Threads Details on Club Lexus SC owner vehicles
94 SC300 NA-T Build
Old 05-07-16, 02:28 PM
tptpete
tptpete's Avatar
I know it's been a while. Quick update..
Starting to source parts through the coming months for an AR-5 transmission swap. Also going to investigate the standalone options. Those plus some fuel upgrades and I should be set to increase the power.
For today I started to paint my calipers that have been sitting around.
Going with black paint, vht clear and white lexus logos I got off eBay. Still need to pick up pads and rotors at somepoint.
Over the last month I had an issue. Car seemed to bog down, rough idle and nearly stall when I eased into the throttle. Long story short, bad wire going to my map sensor. While fixing that I messed up a setting in my SAFC which I didn't catch at firsr... straightened that out and the car is running like a champ.
Old 05-07-16, 07:13 PM
tptpete
tptpete's Avatar
Well just need some clear on the calipers. Pretty happy for my first time. I'm happy I went with black and white.. should look good. Hope they fit! Haha
Girlfriend got a picture of some car booty on my way to work Friday.
Old 04-28-17, 01:09 PM
73luxury
73luxury's Avatar
when you switched to TT gasket, did you have to resurface the block/head? Ive been reading mixed reviews about just decking the head OR doing both. Im going na-t route also an want to do it right the first time. If you did, what were the RA numbers from the machine shop?
Old 04-28-17, 05:25 PM
tptpete
tptpete's Avatar
I don't want to steer you the wrong way, so this is the thread from whom I bought the car https://www.clublexus.com/forums/build-threads/585535-hipsi-s-na-t-build-thread-billet-6265-in-store.html
if I recall correctly he scraped the block clean with a razor and only had the head off to a machine shop. Never had a problems with the end result so it sounds safe. The block doesn't always need work unless it's been beat or the previous owner messed it up. If the head blew it could go either way, but a new gasket, head machined, bolt it down tight and it should be fine.
if the motor isn't in the car is get it done too, but I wouldn't pull it just for the head gasket personally without a reason to.
Old 04-29-17, 01:11 AM
73luxury
73luxury's Avatar
thank you very much for the input, yeah i should be fine then. the motor is already out, actually has been sitting for a couple years due to rear end collision. motor has 153,xxx miles with auto tranny. Anywho ill just send the head off. I dont want to disassemble the bottom block.
Old 08-22-17, 08:13 AM
Boostluv86
Boostluv86's Avatar
Hey man, quick question. What off-set did you go with for the rear wheels? I was looking at the Raijin's as well, and was deciding on +15 or +35. Thanks!
shlomy2000
08-10-17 10:15 PM
Da Coupe
Lexus Vehicles Classifieds
19
01-02-15 11:40 PM
TLDriver
Performance & Maintenance
04-29-09 02:12 PM
ColtSwitch
LX570 / 470 / 450 Classifieds
11-14-06 07:23 AM
Quick Reply: 94 SC300 NA-T Build
