LS460 build, mostly audio system and a bit of the norm
Erikinthe619 (05-04-24)
Setting up the front cover and testing light options
![Name: 20160521_192924_zpsjcgxo2mg.jpg
Size: 173.4 KB](https://www.clublexus.com/forums/attachments/build-threads/420715d1501272676-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160521_192924_zpsjcgxo2mg.jpg)
Had to Solder a bunch of these to get all the leds installed
![Name: IMG_20160528_202551_zpsc7qrblc3.jpg
Size: 182.1 KB](https://www.clublexus.com/forums/attachments/build-threads/420716d1501272676-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-img_20160528_202551_zpsc7qrblc3.jpg)
Got all the panels installed for final fitment. Also got all the edge and back lighting in the amp rack. Plus the glowing panels built and installed in the sub box
![Name: 20160601_184937_zpsa6zgcaxo.jpg
Size: 132.6 KB](https://www.clublexus.com/forums/attachments/build-threads/420717d1501272676-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160601_184937_zpsa6zgcaxo.jpg)
The finished product aside from a few touch ups
![Name: 20160603_211725_zpsdfrv8chg.jpg
Size: 150.3 KB](https://www.clublexus.com/forums/attachments/build-threads/420718d1501272676-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160603_211725_zpsdfrv8chg.jpg)
![Name: IMG_20160604_095604_zpsj735hs0j.jpg
Size: 364.2 KB](https://www.clublexus.com/forums/attachments/build-threads/420719d1501272676-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-img_20160604_095604_zpsj735hs0j.jpg)
![Name: 20160603_211415_zps20odf8jf.jpg
Size: 219.7 KB](https://www.clublexus.com/forums/attachments/build-threads/420720d1501272676-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160603_211415_zps20odf8jf.jpg)
![Name: 20160602_222431_zps4ryby6bu.jpg
Size: 99.2 KB](https://www.clublexus.com/forums/attachments/build-threads/420721d1501272676-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160602_222431_zps4ryby6bu.jpg)
Also building dash pods that go into the factory mid and tweeter location. Built some rings out of 1/2 inch pvc sheet
![Name: 20160527_134653_zpsuuidxeut.jpg
Size: 108.9 KB](https://www.clublexus.com/forums/attachments/build-threads/420710d1501272608-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160527_134653_zpsuuidxeut.jpg)
![Name: 20160527_134633_zpss56uazzg.jpg
Size: 254.8 KB](https://www.clublexus.com/forums/attachments/build-threads/420711d1501272608-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160527_134633_zpss56uazzg.jpg)
![Name: 20160530_213037_zpsvgbyoocx.jpg
Size: 172.5 KB](https://www.clublexus.com/forums/attachments/build-threads/420712d1501272608-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160530_213037_zpsvgbyoocx.jpg)
Added some filler for shape. Just gotta fine tune it and texture
![Name: 20160531_213653_zpsrlr3zsw9.jpg
Size: 149.8 KB](https://www.clublexus.com/forums/attachments/build-threads/420713d1501272608-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160531_213653_zpsrlr3zsw9.jpg)
![Name: 20160531_213824_zpsuxiudplj.jpg
Size: 175.6 KB](https://www.clublexus.com/forums/attachments/build-threads/420714d1501272608-ls460-build-mostly-audio-system-and-a-bit-of-the-norm-20160531_213824_zpsuxiudplj.jpg)
