My indecisive 98 SC300 build
#466
The hre are almost as old as the car, so the finish is still in great shape for how old they are. I forgot exactly when they were manufactured, but probably early 2000's.
#467
I've done a lot of test fits with flush/aggressive wheel fitments in the past, and I've slowly been switching over to big boy tire sizes.
I've spent a couple months researching what exactly is "Supra Spec" and if it transfers directly over to the SC. After looking through a lot of old forum post and FB groups for wheel posts, I found that Supra spec is a range and not a specific offset (since ccw can customize).
The range is as follows:
Fronts: 18x10 +51 to +38
Rears: 18x11.5 +57 to +45
I thought the range was because of a "time/era in modding" type of deal since flush fitments are more popular now. After talking to a couple of my Supra buddies I found out the difference was stock or modified fenders. People who don't want to mod their fenders at all order offsets in the 50's. The guys with modded fenders either order the lower offsets or they order the higher ones and run wider tires.
I contacted a CCW vendor and he said the usual Supra Spec he sells is 18x10+38, 18x11.5+48.
With this information, I went to the SC FB groups and asked people to post their CCW setups with a picture and the following information (Width, offset, and tire size). Most of them didn't have the setup I was looking for, but it was still helpful.
Fast forward to yesterday, I found someone bored enough to help me out with test fits. 18x10+41 18x11.5+52 with a 315/30/18 rear
![](https://live.staticflickr.com/65535/49839570993_8d5028ab8f_h.jpg)
![](https://live.staticflickr.com/65535/49839571233_d8d3c08ab7_h.jpg)
![](https://live.staticflickr.com/65535/49840410082_4f52992639_h.jpg)
![](https://live.staticflickr.com/65535/49839571368_df2d5b51d2_h.jpg)
Fronts: 18x10 285/35/18
![](https://live.staticflickr.com/65535/49840410282_3e0fcea845_h.jpg)
Rears: 18x11.5 315/30/18
![](https://live.staticflickr.com/65535/49840410257_63c623f7da_h.jpg)
Something I didn't know about CCW is that the centercap is the hub ring.
![](https://live.staticflickr.com/65535/49840409907_b8f729f15a_h.jpg)
#468
That looks like a fun PSA. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Interesting that the terminology discrepancy is due to fenders. I would have guessed the same as you.
How does the center cap serve as the hub ring? Is the hub ring a full sleeve that the cap clips onto? Otherwise, how's the wheel get on there...
#469
My friend was telling me the centercap is 1 large piece of metal and the inside (hub side) is machined to the spec of hub bore, so it is installed just like a hub ring, then the wheel slides over it. I haven't seen it in person yet to take detailed pictures.
The SC in the photo isn't mine, it's my friend's wife's car. You can barely see his supra behind it in the first photo.
#472
Weird. I would have thought the center cap gets installed on the wheel and then slipped onto the hub as one. The way you described it, the center cap is just an excessively big, heavy, and complicated hub ring, with an inherent gap that traditional center caps eliminate. I can't come up with any good explanation as to what advantage that would have.
#473
Ordered some acoustic foam to install on the rear deck lid around my sub to support the rear deck cover. I got some extra to see how well it would work in my tool box as liners.
![](https://live.staticflickr.com/65535/49872903951_81fac937d2_h.jpg)
I had my friend do another rear deck for me which is in better condition.
![](https://live.staticflickr.com/65535/49872895871_fb34747c78_h.jpg)
I decided to go with a 2 tone rear deck since the black speaker covers I had were too faded.
![](https://live.staticflickr.com/65535/49872366648_d80a060dbf_h.jpg)
![](https://live.staticflickr.com/65535/49872366583_3e48bba942_h.jpg)
My new steering wheel came in yesterday.
![](https://live.staticflickr.com/65535/49872362653_b38d3cf24d_h.jpg)
![](https://live.staticflickr.com/65535/49873205817_4905940bc8_h.jpg)
I'm still working on the door panels and window trim repairs whenever I have a chance to. The dash will go in last since I'm still waiting on the CF trim pieces to arrive.
#476
The new steering wheel set up is glorious - great find!
#478
The battery died on one of my cars, so I stopped by my friends shop to pick up a new one. It was the perfect opportunity to drive the SC.
![](https://live.staticflickr.com/65535/49878998656_4593453427_h.jpg)
![](https://live.staticflickr.com/65535/49878467328_3d7e80a09f_h.jpg)
I was checking out my friend's S63 since I've never seen it during the day. I've had the opportunity to drive some really fast cars before, but this is one of the most confusing cars I've ever experienced. Given how large and luxurious it is, the car is more sporty than I was expecting. It's hard not to smile when you're behind the wheel.
![](https://live.staticflickr.com/65535/49879309032_1445d05319_h.jpg)
#479
My original plan was to wrap the stock wheel in black leather since I'm getting rid of all the wood trim in the car and replace it with forged carbon parts, but the wheel was going to be about 400-1k depending on if I had them flatten the bottom and add CF. That's way more than I'm looking to spend at the moment. A lot of my friends recommended the RX or SC430 wheel for the time being.
I got lucky, the steering wheel was 110 + tax and the airbag was $70 + tax, so right at the $200 mark. I was expecting the wheel to be beat up once it arrived since it was the cheapest one available, but it's an 8/10 condition.
