Nice suspension setup. I've been away from the GS forums for over 6 years since going to the LS460 but curious if you have the wobble vibrations that were going on with the GS3 AWDs? I had it and couldn't deal with it so curious to know if it was ever solved.
Thanks, the LS is probably where im heading after the GS too. I have some slight vibrations when im sitting at a red light/stop sign, i just put it in neutral til the light turns green. The same problem most people have. The front LCA bushings helped a lot. Nothing bad enough to make me ditch the car or the suspension.
Wow what a beautiful stance how much did it run you I have a 2006 and I'm looking to do the same
Thanks! All in all with everything i have had installed, and including the labor that i didnt do myself im sitting right around $4k. About $1k of that is in labor costs though.
