SC300 1jz+r154 swap
02-07-20, 10:18 AM
Now its painted and installed, looks ok to me, even it has some sights about "modification" but good enough for me.
The following 2 users liked this post by kakezzi22:
02-07-20, 10:44 AM
It came out spectacular, nice work!
02-07-20, 01:29 PM
Quote:
Thank you sir!
02-07-20, 11:45 PM
Quote:
Originally Posted by mrmj2u
Looks really good!
Thank you, only i should have grown the lower part almost half inch more to make it "perfect" :-D But its finished and its good enough!
02-08-20, 02:19 AM
Excellent result! Nice work!!
03-01-20, 05:04 AM
I go with VAG cop ignition and denso spark plugs. Also bought new oem crank pulley(damper), read a lot that 30years old damper could "fly away" :-D
03-02-20, 06:26 AM
^ Nice upgrades! My crank pulley fell apart on my GE and I ended up replacing it with a lightweight aluminum one. However, on my GTE, I kept the stock one knowing that I'll need to replace it at some point in time. I get worried about the horror stories of running a lightweight crank pulley, and on such a nice motor I didn't want to take the risk.
03-02-20, 11:05 AM
I went with a new OEM crank pulley on mine. The only other pulley I’ve heard of people using reliably is the one by Fluidampr which uses, I think, some specific weight of internal gel or silicone inside it vs the OEM pulley’s rubber center.
04-11-20, 12:58 AM
Teflon stainless fuel lines from TORQUE UK. I will make some metal protect plate for the lines.
04-17-20, 09:20 AM
3" downpipe "titanium" tape and aem wideband
04-27-20, 11:10 PM
This week i have been doing my exhaust, 3 inch with 200 cell catalysator.
04-29-20, 06:41 AM
You're going to be brapping in no time!
04-30-20, 05:19 AM
RudysSC
Definitely will be!
04-30-20, 12:20 PM
Yea, have found some extra time for the build. Found some aluminium heat covers.
05-18-20, 10:41 AM
Still working on exhaust. About 3 or 4 small pieces to make and its finish
I have now 6 weeks holidays, trying to get it running before July.
