Gerxiong89 ultrasonic blue mica build
03-05-19, 01:23 AM
Former Sponsor
Quote:
Originally Posted by
Rudiculous
As in cut open or switch out to a 17+ diffuser?
You might be confusing the RC350 quad exhaust with the RCF quad exhaust.
- RC350 is a bolt-on with Lexus 2017+, AIMGAIN, Lexon, or Skipper Diffuserrs
- RCF has a stacked muffler design and will not fit well with factory diffusers (more similar to TOM's rear diffuser)
03-05-19, 01:26 AM
Former Sponsor
Gerxiong89
don't have a 2017 diffuser but I'm sure it will clear. I'm going rcf rear so that's why I went with rcf axleback. However, I did have a RC invidia axleback a while back with my Tom's diffuser and that require some work to fit.
What's the install plan for the RCF rear end?
03-05-19, 10:43 PM
TOPENDMS
wait for it
03-05-19, 11:06 PM
Rear trim cut for cage reinstall.
Cage back in. Doing a seat delete this time around.
03-07-19, 02:01 AM
Pick up a set of used megan rear front camber arm.
Frs trd style side skirts came in.
03-07-19, 02:06 AM
Drl done in rgb and sequential turn signals.
Blue mode on
Regular driving mode.
03-11-19, 12:34 PM
Quote:
Did you post pictures of it in this build thread? If you did, I'll just search for them.
If you didn't, could you? I'm trying to see how it looks from the back and the side.
03-12-19, 01:52 PM
Rudiculous
yes but here are some more.
03-12-19, 05:27 PM
Thank you!
03-21-19, 07:26 AM
Sub box finally came in.
Test fitting the jl 10w3v3. Excuse the mess, will be clean up after I finish the trunk set up.
03-23-19, 12:56 PM
Making template out of left over cardboard.
Wood support on each corner of the sub.
03-23-19, 12:58 PM
First half test fitted.
Just a little more adjustment needed and onto 2nd half. Called it a night.
03-23-19, 01:02 PM
My wheels are finally done.
Works vsxx step lip. Offset in the -22/-17
03-23-19, 01:37 PM
This is one of the most unbelievable 3is builds i've ever seen! Great job!!
03-23-19, 03:00 PM
jimmymac30
Thanks for the kind words. There is actually two to three other 3is builds that are also really nice.
