The Blueberry 400 (manual conversion)
Couple updates while Im waiting for the marlin crawler thrust washer to come in for the R154, doing some suspension upgrades, My rear UCA are going bad so trying to upgradeusing and some poly subframe bushings I got from the UK, thanks!!!
Replacing the Custom manual Pedal with OEM pedal which I winded up modifiing anyways to work with my master cylinder, ACT six puck and pressure plate getting ready to bolt the Flywheel up and put trans back together got the Marlin Crawler thrust washer into my 1st Gear for R154 1UZ!!!!! w00t w00t, pretty excited
Got trans together, welded up ABS sensor hole, clutch went in, and tranny went in, had to level it out some used the driftmotion kit my friend gave me without the spacers was perfect
First drive was good except for my carrier bearing was completely obliterated, so waiting on the the one piece also got my SPEEDOMETER to work again now that the transmission is a toyota sensor, pictuers were taken at TItan motorsports open house 2017
update sold R154, going W58 as I got a great offer on my transmission and adapter setup and I had a W58 with no bell that I had lying around, I also pulled motor and did a couple nice things with it and the bay should be back running here soon, winded up doing a bunch of **** that was not planned for on the car alot to list but Im very excited for it, probably wont be posting much on here but may be some pictures later
Basically a bunch of updates I have done to the car, but Im doing most of stuff on youtube and started sliding, bunbcha cool videos up gunna try and do some more sometime as well
