Otakusan's 2016 IS350 AWD F-Sport
#181
Received 1,736 Likes
Very interesting...I hadn't even considered this (that there would be that much condensation).
KObjective (02-07-22)
#182
Yeah I didn't think about condensation being this bad. I'm scared of the pcv system freezing up then causing problems/ blowing gaskets or something. Wonder is it's a better idea to swap back to stock.
#183
If the ice is only at the bottom, then the crank should still vent into the top portion of the catch can, the oil will fall, and then the air moves into the engine.
Once the ports in and out of the can don't ice over, then you should be ok.
Much like if the can fills with oil and the oil blocks the two ports...still needs to be emptied regularly.
#184
RR racing AOS update. Did an oil change this week and emptied the catch can. It was filled about 1/4 inch on the level gauge. This time it was oil, not all water like in February.
No other updates. I attempted to install some SPC rear camber arms but failed. Couldn't get the inner bolt loose. I had other projects to do, so will leave it for next year.
#185
Got some SPC rear camber arms. Wanted to correct the rear camber as its sitting at over -2.
Setting to stock length. Will get an alignment after driving it for a bit so things settle.
Hardest part is trying to loosen and tighten the inner bolt. Things are so cramped that you can't get tools in there. Watched a couple youtube videos and found the key tools are a flexhead ratchet wrench. Then using another wrench as a snipe
Installed
NICKLASISF (08-24-23)
#186
Installed another part off my checklist. RR racing USRS bushings. Went with the softer street version as my car is awd.
Installed. Was pretty easy. Didnt have to do much prying trying to get the stock off. Watched some youtube videos where guys with rwd models had to pry.
Only issue Im worried about is if I set the preload bolts correctly. I was still able to get the feeler gauge between the washer and bushing on the side closest to the door of the car. Was scared of stripping the threads on the housing. Afterwards I noticed there is a gap between the washer and bushing at the top. Both sides were like this. Not sure if this is normal
Morning test drive. Very smoky were I am as there are a lot of forest fires going on. Verdict: love what these bushings did. Definitely made a difference in steering feel and response. More noticable in the weight of the steering (more heavier/direct), especially switching between normal to sport +. This was the last major part/mod I wanted to do for the car. I don't expect there will be much else. Just planning on maintaining and enjoying it. 😀
The following 2 users liked this post by KObjective:
cuellooo (07-02-24),
#189
#190
#191
Just some older photos from last year. After installing the SPC rear camber arms I got an alignment done. I threw on the Volk wheels. I hadn't ran them for about 2 years as 2 of them developed a slow bead leak. Also wanted to correct the rear camber before running them again
cuellooo (02-01-24)
#192
Also from last fall. Aliexpress special. Got these rubber cup, door, and console mats. The ad didn't show the Lexus emblem. Luckily they look ok. The small rectangle piece was meant for the base models. I use it in the glove box as it fits nicely in the space next to the shelf. (didn't take a picture)
Cup & center console
Door handle pocket
Door lower pocket
#193
First "mod" for 2024. Another Aliexpress special. Got this "Project Mu" reservoir sock
I couldn't stretch it enough to wrap around the whole reservoir. The filler cap neck is also really short. Decide to just fold in the bottom and top bits and wrap it around the cap.
#194
Got this last summer from Etsy. 3D printed fusebox cover for under the dash. Previous owner installed some electronics and used add-a-fuse wiring. This meant the oem lid couldn't be installed
The tabs on the side can be broken off for the wiring. This piece acts as a spacer to clear the height of the add-a-fuse. This model has extra spots for spare fuses and let's you reinstall the OEM lid on top
Installed
