Mingofish Atlanta RCF build
Mingofish (11-12-18)
#348
JBoo
I'm not sure what the % is. I got it from vivid vinyl. They offer like 3 shades. It’s the middle one.
My front tint was removed when I got the xpel put on. I just never bothered to re-tint.
Just FYI it did cut down light output but not real bad.
#349
Well. Few goodies installed yesterday.
Super pro motor mounts and a custom set of solid metal lower control arm bushings.
Wow! Those motor mounts sure are tight. I feel every bump and vibration now.
This isn’t my DD so it’s nbd. Street cars would totally be no good with this mod.
Can’t wait to see how they perform on track and how it effects throttle response.
I was getting, IMO, excessive inner tire wear on the track.
The solid metal control arm bushings were Mike Fig’s recommendation to eliminate front end toe movement under extreme braking.
Had the RR ones, but suspect the urethane still flexed some.
I realize some of the tire wear is due to my high camber, but not all. Let’s see if these bushings make a difference and save me from buying tires.
Will update more next year. Only 2 track days left for the year so I prob won’t be able to tell.
JT2MA71 (12-05-18)
#350
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/1820x2000/28938432_069c_4219_8554_b1eca89e9ace_3de13e46274e26903ef58cfde3ca0cefcf58dddb.jpeg)
Not sure what’s up with the pic upload deal. Couldn’t attach on previous post...
#351
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/1840x2000/0d5ef6a2_2383_4786_a438_16f03cb0e89c_7e9e957722225b8629806150e46b7656ae68ae58.jpeg)
#352
Is it not a good idea to go with the super pro engine mounts for a DD then? I would have thought the solid metal LCA would be the culprit contributing most if not all of the vibration.
Since you're selling your RR penske's what new suspension set up are you going with?
Great build thread. Thanks for keeping us updated with your build.
#353
So here’s my thoughts since both things went on the car at once.
The solid lca obviously will transfer more road surface vibration, but the car seat literally buzz like I’m sitting on a massage chair when the car is at idle, so all that motion is from the motor not being isolated by rubber mounts.
You'll have to wait to see the top secret coilovers. Stay tuned. Haha.
konichiwa3 (11-27-18)
#354
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/1102x818/bf6298ad_b540_446d_b1b7_46f2fb5bd816_1ecc7ce7a130833dcb706e68a059a5b7ea508aad.jpeg)
ILX series Öhlins. Man these things were so pretty! almost looked too good to install and use.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/8df9ae88_a1ae_4a63_997d_b23a4715e31a_9907153858ccbe85eeb6f8df85158c1a7012665f.jpeg)
Fronts installed. Clearance to knuckle seems super tight but I’ve already tracked the car. No issues.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/201eba72_ea85_4ac7_a091_b0cfa0db3837_5a78fcb95fff5e328444003774211ee3c3991938.jpeg)
The rears during installation.
SoSlow (12-05-18)
#355
So I wanted to say that Mike from Figs was totally awesome to work with. Super responsive and delivered what I requested in a very reasonable time frame. Super happy.
The shocks came from ohlins preordered with valve specs by Figs, but the rest were custom made, such as the hats, upper mounts, spacers, etc. The machining & such was top notch, all of it cut from billet and stainless.
There were a tiny hiccup with some hardware that didn’t fit (control arm bolts were too short) but Figs resolved that quickly.
First test drive after install and I already knew the car was riding better on the street compare to penskes.
The penskes were decent on the track but on the street, they were jittery (high spring rate) and a bit noisy for my taste.
These Öhlins doesn’t have any rubber, just like penskes, but they don’t ping or make that knocking sound in the rears.
Mike told me it was the way the pillow ball is mounted (laterally vs radially). Engineer jargon... I’m just glad no noise!
Last Friday was first chance on track with them at Road Atlanta. The initial session out I had them at neutral 12 in both compression & rebound. Both up and down have 24 clicks so 12 is dead center in the adjustment.
Car definitely felt softer (at 12) compare to the penskes but funny enough, the car “set” well and held the line even though car felt like it had more roll. Mike commented that the spring rates he choose was softer than the penskes and that was intentional. I will have to relearn the feel of the car a bit. Softer but still able to hold corner speed is best of both worlds imo.
I made an adjustment (raised compression and rebound 2 click) and ran two more sessions. Car felt tighter as far as not squatting & pitching but the higher compression was worst dealing with track curbs as the car unloaded some. Will have to lower the compression and get more runs in to tweak some more.
Overall a great first day and I’m super stoked about these shocks.
#356
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/51387d20_7fcb_458d_99eb_f2b01f1f7410_24396feca5e23861a3bd9adada3e71e41badd7a9.jpeg)
So for any hardcore track guys out there. These solid lca bearings are a must!!
They took away about 50+% of the steering wheel torque under extreme heavy braking compare to before with the RR urethane ones. Big difference!
Way more road feel as well. They directly transfer the road surface info so you can tell what’s happening underneath the car.
To me, this was the biggest bang for the buck as far as all my track mods to date.
The following 2 users liked this post by Mingofish:
JT2MA71 (12-05-18),
konichiwa3 (12-10-18)
#359
