Build Threads Details on Club Lexus IS-F owner vehicles
RR Racing Supercharger Install
Old 01-10-17, 01:28 PM
St4nc3
St4nc3's Avatar
. I do Smell a DIY Rafi. NICE!!! btw how the Supercharger holding up.
Old 01-10-17, 07:20 PM
Isfast
Isfast's Avatar
Got home late today after a long day. Didn't feel like tackling anything complex.
PLX multi gauge has been installed. AFR, Boost. Voltage. Very cool gauge.
My "floating" gauge
These are the tools I used to remove the OEM crank pulley and install the new one: The chain lever wraps around the pulley (used the rubber to protect the pulley) and holds the crank in place. Then 22mm socket with a long lever to break the nut.
Next up: The supercharger bracket:
GrizzlyMan (08-12-21)
Old 01-11-17, 07:37 AM
RRRacing
Sponsor
RRRacing's Avatar
Received 1,387 Likes on 638 Posts
We recently hit 10,000 miles since installing the supercharger in April. Not one hickup with the SC system, engine, or tranny, and that's with multiple track days and lots of testing/abuse.
We have a bunch of customers working this install right now, so we really appreciate all the feedback and will make all the necessary changes to clarify the instructions, make the install easier, and make this kit as good as it can possibly be.
thanks!
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
breed (01-02-21)
Old 01-11-17, 08:23 AM
St4nc3
St4nc3's Avatar
thanks!
Rafi
Thats awesome man, i do appreciate all the work you guys have dedicated to this platform. and to the OP for the incredible DIY install and picture documentation on this SC. i see you guys are in PA. any chance in you guys coming out to NY to do the install if my mechanic feels it's too much for him to do. He's an old school Spanish mech and installing performance parts on any vehicle scares him because he thinks the car is going to blow up or perform out of its normal duties. lol.
Old 01-11-17, 12:03 PM
Isfast
Isfast's Avatar
Post
Thanks! I will also make myself available to answer questions as I did a few things differently (ie on Jack stands). Rafi, do you want to outsource tech support?
Old 01-11-17, 08:59 PM
Isfast
Isfast's Avatar
Spent a long time today installing the supercharger bracket. Take your time with it.
It is easier with the bottom coolant hose out of the way. Also remove the thermostat. Lot more space to work then.
This is the diagram that RR Racing provides. Use it as a guide:
There is a bolt right above the alternator. Remove that and thread the provided spacer and bolt through the frame at position H
I am pointing at the bolt
Next under the car, behind the crank pulley there are 4 bolts that have to be removed.
The top two are shown in the picture. I have marked it with pink paint. Ignore the one on the bottom. There are two on top (one is hiding behind the other)
These two go into the frame at positions C and D
These are the two on the bottom. They slot into positions A and B.
Below is the bolt that is under the front left side of the valve cover. This bolts on to the frame at position I.
This is what the frame looks like installed:
With the thermostat removed, it is easier to get to the nut shown:
Old 01-12-17, 10:52 AM
Eedo123
Eedo123's Avatar
Just wanted to say I am following your build, looks really good so far man, good luck and can't wait to see more updates and very excited to see the final results!
Old 01-12-17, 08:34 PM
Isfast
Isfast's Avatar
Re-located the fuel injection module.
Installed the supercharger and torqued all the bolts.
bbong (01-13-17)
Old 01-13-17, 09:48 AM
PDP180180
PDP180180's Avatar
Great progress!
Can you give more details of the PLX gauge and sensors you are running? Also how much and where you got it please? PM if you prefer.
Keep up the great work though mate. Will be using this thread for sure when I do my install.
Cheers.
Pete
Old 01-13-17, 06:48 PM
Isfast
Isfast's Avatar
Originally Posted by PDP180180
Great progress!
Cheers.
Pete
Thanks. You can get it from RR Racing. I am running AFR and Boost. It also comes with a voltmeter. Here is a link to the gauge.
http://www.plxdevices.com/Automotive...sors-s/108.htm
Old 01-14-17, 10:38 AM
RRRacing
Sponsor
RRRacing's Avatar
I think it would cost you more to have me drive up to NY and do the install than to just bring us the car! If you are so close, its certainly worth to have us do it, I think.
Rafi
__________________
Phone: 484-756-1777
Facebook : Youtube
Old 01-14-17, 01:49 PM
Isfast
Isfast's Avatar
Couple of things:
When you mount the supercharger on to the frame, hand tighten only. I stripped the threads inside the supercharger and I had to use helicoils to repair. Be careful.
When you relocate the injection module, you will have to extend the ground to the engine and the module. I simply created another one for the engine.
Bought this Dayco Laser alignment and belt tension tool
The pulleys are perfectly aligned
Pulley Belt installed
Thermostat, coolant hose and reservoir back on.
Old 01-14-17, 06:29 PM
LexusNN
LexusNN's Avatar
Best thread on the forum! Congrats and looks great so far
Old 01-14-17, 08:58 PM
Isfast
Isfast's Avatar
Thanks !!...............
Old 01-14-17, 09:00 PM
Isfast
Isfast's Avatar
Extend the MAF Sensor by 5 inches
Quick Reply: RR Racing Supercharger Install
