Build Threads Details on Club Lexus IS-F owner vehicles
RR Racing Supercharger Install
Old 01-15-17, 06:51 PM
  #31
MileHIFcar
MileHIFcar's Avatar
Looking good so far!!!
Quality engineered kit from Rafi and the crew
Can't wait to get mine (one of these days)
Old 01-15-17, 08:56 PM
  #32
Isfast
Isfast's Avatar
Yes. Quality engineering indeed. Parts are extremely well made and aesthetically pleasing as well. Take a look at the CF parts:
I ceramic coated all the pipes, inter-cooler and the clamps in satin black.
Remove the passenger side brake duct
The inter-cooler has to be spaced out from the chassis so it does not hit anything. I went with a collection of nuts until I can find something better than that or washers.
Inter-cooler installed
The outlet piping from supercharger to inter-cooler done
Old 01-16-17, 04:57 AM
  #33
mikersoft
mikersoft's Avatar
Subscribed to follow your progress.. Looking good so far!
-Mike
Old 01-16-17, 11:26 PM
  #34
PDP180180
PDP180180's Avatar
Looks great.
Nice progress. You guys are so lucky to have access to cool shops to do stuff like ceramic coating. Places to get that sort of thing done in the U.K. are few and far between. Even if you do find someone that'll take on the work, costs can be pretty high. Supply and demand I guess!
Maybe RR-Racing can offer the ceramic coating as an optional extra? Be good if you could buy it ready done.
Keep it up though Op.
Not far off firing that bad boy up!
Old 01-17-17, 01:20 PM
  #35
RRRacing
Sponsor
RRRacing's Avatar
Received 1,387 Likes on 638 Posts
Originally Posted by PDP180180
Looks great.
Actually, we include a silicone wrap tape, it doesn't chip and looks good. There are only two pipes that are visable. For the intercooler, we can paint them black, we just use a standard Eastwood black radiator paint, I suppose its better than regular paint as they claim it is specifically formulated for radiators/intercoolers.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old 01-17-17, 10:21 PM
  #36
Sameer89
Sameer89's Avatar
Nice progress! What part of Florida are you in, if you don't mind me asking? Would love to see this setup in person!
Old 01-18-17, 02:44 PM
  #37
Need4Speed
Former Sponsor
Need4Speed's Avatar
Nice
Old 01-18-17, 08:27 PM
  #38
Isfast
Isfast's Avatar
Delray Beach
Old 01-18-17, 08:38 PM
  #39
Isfast
Isfast's Avatar
Let's revisit the pipe install. Had to re-do it twice as the clearance is tight. The way I originally had it would interfere with the lights. Notice all the angles of the pipes:
Notice how the upper intercooler pipe is tucked behind the frame:
Very tight clearances:
Any place that I thought would rub, i stuck a small piece of slip tape. This is what skateboarders use to slide on pipes. The material is tough as nails and has a low coefficient of friction.
Installed the first BOV and CF pipe to the throttle body:
Also put the gauge modules in an enclosure to prevent water from getting in. Still have to close it off.
jreancsu (03-19-21)
Old 01-18-17, 09:23 PM
  #40
MileHIFcar
MileHIFcar's Avatar
Looking good!
What size rubber are you going to run (type of tire & width) to try and combat slippage with the newfound power?
Old 01-18-17, 09:36 PM
  #41
Isfast
Isfast's Avatar
Originally Posted by MileHIFcar
Looking good!
275 NT01 for the track (square setup)
275 NT05 for the street (square setup)
Old 01-21-17, 08:05 PM
  #42
Isfast
Isfast's Avatar
Finished the intake pipes and BOV, clearance is very tight. Took hours to adjust and check for clearance.
Inserted the valve into the AOS. There is an arrow on it. It should point to the manifold.
Removed the stock breather hoses and installed the RR ones with a filter.
Old 01-22-17, 02:48 PM
  #43
Vitveet
Vitveet's Avatar
Very good work and kit looks of superb quality!!
Few questions. Are you going to permanently lose the passengers side brake air duct? And how about the fog lights?
I know Rafi had mentioned before that the fog lights will be sacrificed in the kit....No work around for it from what you can tell?
Thanks for taking the time to take pics and do a write up!!
V.
Old 01-22-17, 03:18 PM
  #44
Isfast
Isfast's Avatar
V.
Yes. The passenger brake duct will not be used. I did not have an issue with the fog lights. The LED one is a tiny bit shorter than the regular one (see pic below). I test fitted my bumper and it was fine. I think Rafi re-did the kit to make it fit. In some cases the housing will have to be trimmed.
Old 01-22-17, 03:25 PM
  #45
Isfast
Isfast's Avatar
Today was bumper cutting day. Eat your wheaties. Did it with a hand saw.
Passenger side:
Cut the foam to fit:
Driver's side:
Pieces that were cut out:
Supercharger cooler done and lines routed:
Under-tray installed:
Banjo bolts, filter and reservoir fitted:
Quick Reply: RR Racing Supercharger Install
