Build Threads Details on Club Lexus IS-F owner vehicles
RR Racing Supercharger Install
Old 02-02-17 | 11:30 PM
  #76
PDP180180's Avatar
PDP180180
Nicely done.
So, now you've completed the install, what would you say are the top 3 most tricky or difficult steps with the install?
Can you also confirm what tools you used, and any specialist tools?
Don't blame you at all for wanting to take it easy for a few miles. A lot of time and money has gone into your car, best to make sure it's all happy and working the way you want it to.
Great thread though, thanks again for taking the time to document your work.
Old 02-03-17 | 02:10 AM
  #77
Scott610's Avatar
Scott610
Default Congrats on supercharger
Wish I could do the same and looking forward to videos
Old 02-03-17 | 09:34 AM
  #78
USB_F's Avatar
USB_F
One of the best threads I've seen on here
Old 02-03-17 | 11:01 AM
  #79
JDMV8's Avatar
JDMV8
I spy a dakar yellow e36 and a pretty monstrous ISF
nicely done man
Old 02-03-17 | 06:33 PM
  #80
Isfast's Avatar
Isfast
Originally Posted by PDP180180
Nicely done.
Thank you!!
Any special tools are shown in the thread. Everything else is standard.
Adjusting the pipes so that everything fits. This took me two days.
Re-routing the trans cooler lines. Messy messy job.
Bumper fitment to get it perfectly lined up.
Old 02-04-17 | 01:25 AM
  #81
Defratos's Avatar
Defratos
Sub'd nice work mate
Old 02-04-17 | 05:52 AM
  #82
Jz39's Avatar
Jz39
I don't see any pink in your coolant tank?
Old 02-04-17 | 02:06 PM
  #83
ljdsong's Avatar
ljdsong
Raj admire your patience in doin this DYI to the community. Any issue with regards to alignment of your pulleys? Im done with my install,but had an issue with the alignment, i did the laser alignment on the crankshaft and the lower ribbed pulley only, cant access the top pulleys with the gates laser tool, i think the thermostat manifold blocking the laser alingment tool. Any inputs from the community before i teardown the supercharger again. Here some pics of the issue:
The belt jump out from the blower pulley and crankshaft.
Leo
Old 02-04-17 | 10:49 PM
  #84
Isfast's Avatar
Isfast
It's at the right level. It's there.
Old 02-04-17 | 11:00 PM
  #85
Isfast's Avatar
Isfast
Leo
Leo. looks like it jumped one groove to the right. But if it jumped one groove on the top and bottom, then would it not be in the same position (alignment) as when you started?
Couple of questions: How many miles before it jumped? How hard have you accelerated? What RPM? Did your belt squeal at all?
I took the thermostat out when I did the alignment. So I was able to do both top and bottom. I would do that first before tear down. Also check the tension. I tightened the tensioner on to the bracket too much and it was sticking. I backed off half a turn and it is fine now.
My belt squeaks at start up, but goes away. I hope that it does not jump. Would suck to tear it down again.
Old 02-05-17 | 10:20 AM
  #86
ljdsong's Avatar
ljdsong
I start agressive driving at 75 miles, the first start up i dont have or hear any problems . The junping of the belt maybe i got already 85 to 90 miles when the STi provoke me at the freeway. Probably at 6500rpm.Today ill try to put back the belt on proper position but when i start it up it jumped again . During my install i have this gates dot laser alignment tool but i cant point it to blower pulley from the crankshaft coz the thermostat manifold is blocking the pathway of the laser even i take out the thermostat it self. The blower sounds perfect and no squells sound. Rafi suggested to put some washers on the X and Y blower bracket.
On positive side the power is there. Cant
complain.
Hopefully yours will be perfect, too much work if had to teardown it again.
I ordered dayco alignment tool, same as you.
Old 02-05-17 | 11:07 AM
  #87
Isfast's Avatar
Isfast
complain.
So it jumped again at startup? Check all the bolts on the supercharger frame while you are at it. Also check the movement of the tensioner. Keep me posted
Old 02-05-17 | 07:40 PM
  #88
Isfast's Avatar
Isfast
Went to change the oil and top off the trans fluid. Small problem. Could not get the oil filter housing off as it hits the supercharger bracket. So used a dremel to sand the fins down. No issues now.
Old 02-07-17 | 02:59 PM
  #89
2URGSE's Avatar
2URGSE
Very very nice.
Are you getting the car custom tuned on the dyno or running the original map?
Old 02-07-17 | 06:29 PM
  #90
Isfast's Avatar
Isfast
Originally Posted by 2URGSE
Very very nice.
For now running the RR supercharger map. Will datalog and send to Rafi once I have worked out some stuff on the car.
