Build Threads Details on Club Lexus IS-F owner vehicles
RR Racing Supercharger Install
Old 02-08-17, 07:38 AM
  #91
FilwithanF
FilwithanF's Avatar
Originally Posted by ljdsong
Raj admire your patience in doin this DYI to the community. Any issue with regards to alignment of your pulleys? Im done with my install,but had an issue with the alignment, i did the laser alignment on the crankshaft and the lower ribbed pulley only, cant access the top pulleys with the gates laser tool, i think the thermostat manifold blocking the laser alingment tool. Any inputs from the community before i teardown the supercharger again. Here some pics of the issue:
The belt jump out from the blower pulley and crankshaft.
Leo
Had this same issue on my 2008 Civic Si with the Kraftwerks supercharger (C30 Rotrex). My mechanic told me that the tensioner and the pulleys were out of alignment and that the tensioner would need to be shimmed. Hope you figure this out sir!
Old 02-11-17, 08:37 AM
  #92
RRRacing
Sponsor
RRRacing's Avatar
Received 1,401 Likes on 643 Posts
I start agressive driving at 75 miles, the first start up i dont have or hear any problems . The junping of the belt maybe i got already 85 to 90 miles when the STi provoke me at the freeway. Probably at 6500rpm.Today ill try to put back the belt on proper position but when i start it up it jumped again . During my install i have this gates dot laser alignment tool but i cant point it to blower pulley from the crankshaft coz the thermostat manifold is blocking the pathway of the laser even i take out the thermostat it self. The blower sounds perfect and no squells sound. Rafi suggested to put some washers on the X and Y blower bracket.
On positive side the power is there. Cant
complain.
Hopefully yours will be perfect, too much work if had to teardown it again.
I ordered dayco alignment tool, same as you.
Hi Leo... per the instructions, make sure you set both BOV's to the softest setting, this minimizes backpressure to the SC when you lift off throttle at high RPM.
Of course, as mentioned here it could be alignment. That said, we have never had a belt jump a tooth.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old 02-14-17, 01:01 PM
  #93
rselby
rselby's Avatar
any updates...
Old 02-14-17, 05:58 PM
  #94
Isfast
Isfast's Avatar
Originally Posted by rselby
any updates...
None. I am getting my other track car ready for this weekend. I have not driven it for a couple of weeks. I'll get back to it soon
Old 03-01-17, 12:37 PM
  #95
Vitveet
Vitveet's Avatar
Ever get this car out on the road?!
V.
Old 03-01-17, 04:25 PM
  #96
MLRSTJ
MLRSTJ's Avatar
Any update?
Old 03-02-17, 08:50 PM
  #97
Isfast
Isfast's Avatar
V.
Yes about 200 miles so far
Old 03-02-17, 08:51 PM
  #98
Isfast
Isfast's Avatar
Originally Posted by MLRSTJ
Any update?
Will have some this weekend.
Old 03-04-17, 05:11 PM
  #99
Vitveet
Vitveet's Avatar
Can't wait to hear your review!
V.
Old 03-05-17, 08:49 PM
  #100
Isfast
Isfast's Avatar
On startup, my supercharger belt had a loud chirping which went away once the car warmed up. This weekend, I pulled the pipes apart and reinstalled a gatorback belt from continental. These belts are supposed to be much quieter due to their design. Rafi also recommended that I reverse the wheel on the tensioner so that the ring clip is facing the front of the car. No more chirping!!!!
Regular belt:
Gatorback Belt:
Part Number:
Belshe1993 (04-10-21)
Old 03-06-17, 06:46 PM
  #101
Isfast
Isfast's Avatar
Break from Supercharger install.
Installed Toms Rear Diffuser and Wald Trunk Lip:
Old 03-06-17, 07:17 PM
  #102
5ltrv8
5ltrv8's Avatar
Looks really awesome...can't wait to see a video your F With its new found power! Have you been able to run it through its paces yet?
Old 03-06-17, 08:27 PM
  #103
Isfast
Isfast's Avatar
Some. Only took it up to 3 psi. Car pulls pretty hard. Need to do compression check and data log before I can push it hard. Maybe next week.
Old 03-06-17, 08:50 PM
  #104
Isfast
Isfast's Avatar
Video with new belt:
https://drive.google.com/open?id=0Bx...mtxMzN1bUtiTjA
BS ISF (03-07-17)
Old 03-07-17, 09:44 AM
  #105
MLRSTJ
MLRSTJ's Avatar
HIGHLY RECOMMENDED. I'm having to rebuild my motor after only 300 miles with Supercharger installed.
GrizzlyMan (08-12-21)
Quick Reply: RR Racing Supercharger Install
