Build Threads Details on Club Lexus SC owner vehicles
Jimmy Mac 1999 SC300
Old 09-16-17, 08:59 AM
  #331
LexIS007
LexIS007's Avatar
Looks so good! That blue is something else...
Old 09-16-17, 10:29 AM
  #332
jimmymac30
jimmymac30's Avatar
it certainly is sexy.
Old 09-21-17, 01:35 PM
  #333
myLEXsc400
myLEXsc400's Avatar
these HRE wheels make your car look so damn good. wow!
Old 09-27-17, 06:51 PM
  #334
jimmymac30
jimmymac30's Avatar
im Doing a near full engine bay wire tuck and battery relocate now. Then the 5 speed. Yup, it used to be white lol
Old 10-06-17, 07:50 PM
  #335
jimmymac30
jimmymac30's Avatar
Ok. So I kind of did a thing. I bought a turbo... manifold... down pipe... exhaust... intercooler.... piping.... bov... wastegate.... yup. It’s happening. Lots to come. I’ll post pics when I have a chance. Mean time...
Old 10-06-17, 08:00 PM
  #336
97-SC300
97-SC300's Avatar
Let the games begin!
Old 10-07-17, 05:32 AM
  #337
jimmymac30
jimmymac30's Avatar
it’s goong to be a good winter! Trying to decide on fuel management. My car is obd2 :-( so the easiest way would be to register the car my dads house where emissions don’t exist. But the IS300 guys have worked through this (remember my car is vvti so there is no obd2 stock turbo computer). So maybe an AEM FIC. I’m going to call sound performance and see what they suggest since they will be tuning the car.
Old 10-07-17, 12:06 PM
  #338
Blkexcoupe
Blkexcoupe's Avatar
This build keeps on getting better and better.
Old 10-11-17, 11:01 AM
  #339
2KHarrier
2KHarrier's Avatar
Nice progress JM
Old 10-12-17, 05:33 AM
  #340
jimmymac30
jimmymac30's Avatar
Thanks guys. I think I am making some progress as my parts pile just keeps getting bigger and bigger. I am currently looking for fuel systems to use. I’m certain that with my low power goal of 450 I can run a single walbro pump with the stock lines, aeromotive FPR, and 550 injectors (might go 725cc injectors though) any thoughts are appreciated.
Also found a company in Georgia that makes patch harnesses for the 98-00 SC300 (also the IS300 and 98-01 gs300) so I can retain use of my stock computer while using an AEM V2 to control everything needed by the motor. Www.dezod.com. Any input there would also be greatly appreciated.
So once the fuel and ems are figured out, it’s on! Yes, I’m staying vvti. No, I don’t think I’ll be doing a full gte swap. Am I dumb for this, probably. I’m going to push my weak rod block to 450 hp. If it blows up, I have quick access to a 92-97 ge block. Or maybe I’ll be smart and just switch the block first.
So so if anyone has any input on fuel system or ems, please let me know. I contact Spund Performance and they have no issue tuning the AEM V2. They basically just said “don’t get a V1” so I won’t.
Old 10-12-17, 09:34 AM
  #341
gerrb
Super Moderator
gerrb's Avatar
Will they piggy back your SC300 ecu with the AEM v2 ? Just wondering why ? Ask them if they are giving you the 30-6100 AEM V2 ? If not ask them what is the AEM V2 model number of ECU they are providing with that deal.
Old 10-12-17, 11:50 AM
  #342
jimmymac30
jimmymac30's Avatar
accordbg to chris it isn’t a piggyback but rather a “parallel” system. I’ll find out about the box part number.
Old 10-12-17, 02:40 PM
  #343
KahnBB6
KahnBB6's Avatar
Received 1,237 Likes on 864 Posts
I'm excited for the new phase of your project, Jim! It didn't take long!
^^ I can't offer anything about the way you'll be using the AEM V2 but regarding the 98+ GE VVT-i block vs your 92-97 GE block I'd recommend using the latter from the start. Even with some more miles on it you'll already have all the rod and piston strength you'll need for your goal. As I've understood it you can get away with some reliable boost to at least to 300hp crank on the stock GE VVT-i bottom end but I don't think 450hp crank will last for long. They are the same blocks and cranks anyway with exactly the same deck heights so you could just keep the GE VVT-i block for an even more built up replacement bottom end down the road.
Regardless, I am eager to see this come together! It sounds (and looks) like you will be moving fast on the engine build
Old 10-12-17, 06:27 PM
  #344
jimmymac30
jimmymac30's Avatar
Originally Posted by KahnBB6
I'm excited fro the new phase of your project, Jim! It didn't take long!
thanks craig! It IS moving fast. Just picked up my FFIM, fuel rail, 1200cc injectors (overkill, yes) and a ge exhaust manifold. It’s moving in the right direction. And yes, I’ll use the 92-97 block. Even if it does have 200k miles
Old 10-12-17, 07:28 PM
  #345
KahnBB6
KahnBB6's Avatar
^^ That all sounds great! Good on using the 92-97 block. It just eliminates one more weak point in the system. 200k miles can still be okay to use for boost if the rings are in good shape. Usually we recommend doing a compression and/or leak down test but without a head on it it's moot, I think. Get some ARP head studs and an OEM 2JZGTE head gasket or a thicker one for less compression with the GE pistons if you need/want (such as an HKS 2.0mm) but the OEM GTE head gasket is what most people use with 92-97 block NA-T setups. I am not sure how different compression ratio will be with the cylinder head combustion chambers in the 98+ VVT-i GE head though. You'll be fine of course but it's the exact final compression number you might want to know.
Are you going to build your fuel system for E85 flex? And are you staying with the W58 transmission that you picked up last month? If you use that it may be safer to keep your initial tune closer to 300-350whp max. How it will live even against that level of power depends on how you operate it, especially in regards to when you boost load it's relatively small internal gears.
I just realized a white SC is in the picture above! Is this an engine project for your blue restored SC or this white one?
Quick Reply: Jimmy Mac 1999 SC300
