Build Threads Details on Club Lexus SC owner vehicles
Jimmy Mac 1999 SC300
Old 11-16-17, 07:00 PM
  #421
KahnBB6
KahnBB6's Avatar
Received 1,237 Likes on 864 Posts
Originally Posted by jimmymac30
Thanks Craig! It won’t be ready for a few months still. Have to build a harness, run fuel, etc. but it IS getting closer for sure.
To answer your question:
the vvti head has a hard line with 2 banjo fittings to provide oil to the vvti.
Powerhouse racing makes a 1/8” npt adapter to allow the use of the factory banjo bolt from the vvti where the oil pressure switch used to be.
I will use the is300 banjo bolt feed the turbo. I will put a T there to accommodate the oil pressure switch.
Well, as it currently stands you're getting very close with the biggest parts of the process, save the engine wiring harness.
Excellent with the VVT-i solenoid oil feed. I'm glad to hear there is already a proven way to get a GTE VVT-i head onto any early 2JZ block. The oil pressure switch location is perfect.
Are you going to leave the engine out of the car until you can get the new harness fitted onto it? I've heard it is much easier to install a harness before the engine goes in.
Old 11-17-17, 07:36 AM
  #422
LexIS007
LexIS007's Avatar
yes I have.
Do tell...???
Old 11-17-17, 11:06 AM
  #423
jimmymac30
jimmymac30's Avatar
Originally Posted by LexIS007
Do tell...???
i got a heck of a deal on a W55 from an is300. It’s cool cause the guy told me it’s made of glass. I was like “perfect! I love having something no one else has!” Cost me like $6k but he guaranteed me I’d be the only sc300 or Supra with it so... it’s pretty exclusive! 😂😂😂
Old 11-17-17, 01:46 PM
  #424
KahnBB6
KahnBB6's Avatar
i got a heck of a deal on a W55 from an is300. It’s cool cause the guy told me it’s made of glass. I was like “perfect! I love having something no one else has!” Cost me like $6k but he guaranteed me I’d be the only sc300 or Supra with it so... it’s pretty exclusive! ������
Well played, sir
Old 11-17-17, 09:58 PM
  #425
LexIS007
LexIS007's Avatar
Geez, sounds like the same guy that gave me a $6k estimate on my SC’s body repair . Only difference is, I didn’t want to be so exclusive....lol.
Don’t waste ur time with a “W” series anything. Build the auto, or go some 6spd.
Old 11-18-17, 03:39 PM
  #426
jimmymac30
jimmymac30's Avatar
I will rock this W transmission until it fails me. Might be sooner than later, but it’s happening.
myLEXsc400 (12-01-17)
Old 11-20-17, 08:08 PM
  #427
jimmymac30
jimmymac30's Avatar
Getting the engine bay wires tucked. Decided not to relocate the fuse box to the trunk. Painted it to blend in. Turned out really nice. Oh and yes, I completely sand blasted the crash bar. It looks brand new. Too bad no one will ever see it.
Old 11-20-17, 08:51 PM
  #428
ThomasGS4
ThomasGS4's Avatar
Absolutely stunning!
Old 11-21-17, 02:52 AM
  #429
jimmymac30
jimmymac30's Avatar
thanks Thomas! Attention to detail is key for me. Glad you like it.
Old 11-22-17, 06:12 PM
  #430
jimmymac30
jimmymac30's Avatar
Phr vvti fitting
Phr vvti fitting
Phr vvti fitting side
Stock oil pressure switch location on non-vvti block where Phr fitting goes
Phr power steering reservoir
Fit the turbo and started plumbing
Wastegate installed
Vvti line installed with Phr fitting
Craig, got the fitting from Powerhouse Racing for the vvti. Took a few pics which I will attach. It works flawlessly. Also started to plumb my turbo, put new motor mounts on, install my PHR power steering reservoir, finished installing my wedge seat brackets. Been a productive few days. Also finished my wire tuck. Man, go me. Lol
Old 11-23-17, 12:01 AM
  #431
KahnBB6
KahnBB6's Avatar
Jim, I just caught up on this and the progress is great! That engine looks beautiful!! The PHR oil pressure switch location to VVT-i solenoid adapter is certainly the business. You're gaining on this! Will the wiring harness be next?
Seeing the progress on your car is always a treat and you cover every detail in your build. I still say this is going to go much faster than you think it will!
Old 11-24-17, 12:00 PM
  #432
Blkexcoupe
Blkexcoupe's Avatar
At the rate you're going, you'll probably finish at the start of winter and have to look at the car until the weather gets better for you.
Old 11-24-17, 04:53 PM
  #433
jimmymac30
jimmymac30's Avatar
its still a LONG way from complete. Fuel system, wiring harness, intercooler mounting, intercooler pipe hole cutting, run coolant lines for turbo, finish lines for oil for turbo, cut hole for trans, install pedals, throttle cable, clutch master, brake master... the list goes on lol
Old 11-28-17, 06:41 PM
  #434
jimmymac30
jimmymac30's Avatar
Well, it’s in! There’s still a ton to do, but here’s some pics for now.
Old 11-30-17, 06:10 PM
  #435
Blkexcoupe
Blkexcoupe's Avatar
I've never understood the appeal of ganador mirrors, but I know how hard they are to find, so congratulations to you.
Quick Reply: Jimmy Mac 1999 SC300
