"Baby"
#31
ah, yes the year might make a difference but whatever the case, i will need to roll the fenders to fit the tires that i want. Also vteruni was my old handle years ago, I have no idea how you found it. Just stick to V
#32
Some more pics of the exhaust and one more little upgrade i did last night.
Exhaust:
Trunk light!! I was so tired of my trunk light being so dim that i decided to get an led strip for it. Looks amazing at night and only $10!!
Exhaust:
perfctreig (01-16-21)
RudysSC (04-29-20)
#35
FINALLY pulled the trigger and got the engine splash shield!!!. Looks awesome and the quality is top notch. Now I just need to get the bolts to attach it. Anyone know what size i need?
EDIT: Well to my surprise, the bolts and clips that i need are included. I did not expect this and only realize that they were there because i stepped on them lol
RudysSC (04-29-20)
KiroLS (11-21-20)
#39
I kinda like the plastic on the front. Looks cleaner when put together with the big metal one. But you should totally do it. Very impressed with the quality and it comes with a nifty carbon fiber stamp out of our car's silhouette for your key chain.
#40
Bbk
Sooo the driver side caliper seized... Decided to go ahead and pull the trigger on the LS400 BBK. EBC rotors, posi quiet pads, stop tech SS lines all around and a brake flush.
PICS
PICS
#41
Hey V
Those brakes and wheels look great together. I have the same wheels and I am working on them now to bring them up to look as good as yours. Don't forget to obtain a spare wheel and tire that will fit those front brakes. Good luck.
#43
Thanks Kira. The brake pedal feels a bit more stiff and responsive compared to the OEM. This is likely to due to the SS lines though but the biggest difference comes in when i have to slam on the brakes for any reason what so ever. Any emergency stops in the car are now significantly better and in turn, the car feels safer. During the bedding process i had my roommate in the car with me and let me tell you, this man was freaking out. I highly recommend doing this upgrade if you haven't already. Only thing i would do different is go with the stop tech slotted rotors and some kind of performance ceramic pad that has a bit more initial bite without being too dusty. PosiQs are very nice pads but I was hoping for a little more initial bite. Still better than stock though.
#45
I actually ended up using plan old superglue from i bought from dollar tree. the caps have been taken off and put on multiple times by multiple shops without a single issue. I would use liquid nails if i had to do it again though. the cleanup around the edges after using superglue is a nightmare
