I know most aftermarket intakes don't add alot power to our cars, but I had this lying around and decided to install. Also did a thorough cleaning inside stock airbox, MAF sensor and throttle body before installation
Initial testing does not reflect any more noise level than my Joe-Z intake tube and hi flow aFe panel filter. Tested on start-up and revving engine up through the powerband. A test drive will tell me more hopefully.
Look ma, No stickers!
Reason: Pics
Just my 2 cents, but this mod actually cost me hp, and caused a nasty spike in my AFR readings when I had it dyno'd.
Swapped back to HPS intake pipe and K&N panel filter with OEM airbox, gained 10hp, and corrected my AFR readings.
Each to their own, but thought I’d share my experience.
Loving the build otherwise though mate.
Yeah I just began testing yesterday. Went for a test run last night and my thoughts after an hour of driving were potential power loss down low and some gain up top. But this could be the placebo affect. I will more than likely go back to my JOE Z intake and panel filter if not saitisfied after a couple of days
