Aspect's 07 IS250 AWD
Aspect (02-08-18)
#78
Couple of quick shots I took while there was a little day light left. I love the way they look. Fitment is 8/10, the weather stripping is kinda eh and doesn't sit perfectly flush but good enough. Quality is about 8/10 or 7/10, overall construction is nice but im not sure because it's a clear lens that I can see the white glue holding the light together (maybe the sealant glue?) around the edges. I'll upload a pic of it later, if anyone can confirm whether it's standard or not.
#79
Not a mod but a much needed fix. 2 years of owning this car with a dysfunctional trunk I've had enough and ordered some new struts. Works like a charm now.
#81
It took me 8 years to fix mine...I didn't even know it was an issue just thought after I installed my OEM spoiler that it just made my trunk heavier and causing it to slam. I bought $26 Amazon ones, they didn't have the OEM still clip on the inside portion, so I had to use some $0.25 "e-clips" from Ace Hardware to keep them in the shaft.
#82
#83
Morimoto M-LED Projectors Spec D Retrofit complete!
In my opinion they look amazing and the output is blowing me away, at least compared to my previous halogen or led bulb setups. Might have to adjust the height a little lower but it'll be fixed when I put it back on coilovers in the summer anyways. Didn't do the chip flip mod because it didn't seem to seat properly when flipped compared to stock so I left it. People complain about the width but I think it's good, pictures don't really do it justice, I'll try using my Sony later
#84
Those look nice! I didn’t realize the ‘M’ is projected on the ground, but it’s a neat little feature. What’s the color temp of them? 6000k?
Also just out of curiousity, do the new trunk struts open your trunk without needing to assist it with your hands or after pushing the release button do you have to pull the trunk lid up still... thanks
#85
The new struts are decent but still require you to lift the trunk about past the 60 degree point before it does the rest
#86
Just remembered to upload my new sound clip. The exhaust is back to being nice and quiet at low RPM but keeping that straight through sound >4k RPM. Def suits my taste more.
https://youtu.be/vzjhoOswtn4
#87
I'll update you in terms of the weight of the Tanabe if I ever take it off before you get yours... future plans in the works
Edit: https://www.clublexus.com/forums/per...250-rwd-2.html
Tanabe dyno'd the exhaust at about 5 whp
MikeFig82 (03-12-18)
#88
Spring is almost here. Got a couple parts ordered and coming in to be installed this week or so. Looking to finish this build up this year with a couple small things
#90
Lowered again and the lip is on. Leveled the coilovers again to make sure its all 25" ground to fender
Some future plans in the works too
