hi all
im finish my GSF front conversion. More details at my *non-commercial* blog zatonevkredit.ru
photo is attached here
parts used :
52131-24100 - bumper amplifier
53289-24020 - radiator protection
51409-30060 - Anther of the engine
52611-24110 - foam plastic garbage between the bumper and the bumper amplifier
52114-24161 - registration for the license plate
52136-24051 - fastening of foam plastic garbage
52135-24061 - fastening of foam plastic garbage
85354-30170 - covers for headlight washer
85353-30170 - covers for headlight washer
85361-30360 - Washer Nozzle Mounting
85362-30320 - washer nozzle mounting
85207-30150 - washer nozzle
85208-30150 - washer nozzle
53207-24040 - air duct for brakes
53208-24060 - air duct for brakes
53805-30510 - locker
53806-30440 - locker
53181-30060 - plastic insert in the headlamp
53182-30060 - plastic insert in the headlamp
If the headlamp is without computer blocks, then the block numbers
81107-48C90 - headlamp controller (trinocular + AHS)
81108-48C90 - headlamp controller (trinocular + AHS)
90075-23003 (x2) - ring for hermetic sealing of the block
-- пакеты штатного приборного щита. Щиток шлет их
-- когда переключается состояние света
~6700, but headlights like new and with computers
1600 for bumper+grille, 1600 for each headlight+computers
~1500 for screws, plastics, anythig from long parts list in 1st post
Looks really nice. I don't see that you listed the grilles (top and bottom) on your parts list. I have been trying to buy all the parts for this conversion as well.
Can you please confirm what cost for the grilles and surround trim pieces. Did you get them new or used?
all of this already posted at my blog, but in russian
Andrey, Let me ask you couple questions.
I did everything as you posted: wired new lights, code the arduino (beside the fake headlight emulation cause i have xenon light) but there are some issues that i cant figure out.
1. I have check headlight leveling system message constantly blinking. I disconnected the original AFS module, but techstream successfully communicating with that unit until light is OFF., however body ECU has an error communication with ECU. Once I turn the light ON, techstream stop see the AFS unit at all). I believe that there are kind of analog of AFS module installed in left headlight ballast. Question is why it stop communicating with techstream once light is ON and why Body ECU dont see it?
2. All data packages works beside the one when only DRL is ON and one for startup the lights (when low beam is ON and high beam diodes starts simultaneously) (I think it wasnt in your arduino code)
