FSport's IS-350 running list of service & maintenance DIY
#331
Interested in locating a post / or additional information about removing / installing the two motor / engine mounts (Part # 12361-31201, left & right front engine mount), 2006-2013 IS 350 RWD.
Apologies if I may have overlooked however, did not come cross using the Search This Forum tool.
Worst case is you also have to undo the block extensions and even that doesn't look difficult. I will say that because the oil pan is so far South, this could result in lifting the trans more than the engine so be ready to make adjustments to blocking location.
What makes you think they're bad?
#332
2013FSport, thanks for following up. Have yet to install the new motor mounts (art # 12361-31201, left & right). When time permits, have decided be bring vehicle to service station for installation.
MrHarris (03-27-22)
#335
Two years new'ish 350 front sway bar end links are making captain crunch sounds. Anyone know what the difference is between these two PN's listed? The bottom set is cheaper and says it fits ours and the IS-F if that helps.
Is this why others installed the IS-F bar?, because the F-Sport one kills the End links?
I installed these just shy of 2 years ago. Cost was $60 then.
48810-30070 Left $82.59
48820-30090 Right $82.59
Fitment is RWD IS250, 350, GS350, GS450H, GS460, GS430, GS300. Lexus stabilizer link
And I see these PN's too!
48810-53010 Left $59.40
48820-53010 Right $59.10
Fitment is IS250 350 IS-F
TIA
TIA
#336
Sadness.... less than 2 years on new front sway bar end links coupled to F-Sport anti-sway bar and the links ball is making capt. crunch sounds.
Anyone know if IS-F links are a direct swap?
Is this why others installed the IS-F bar? I like how it takes the corners as is, but $140 in end links every 2 years is silly.
2013FSport (05-16-22)
#337
I don't know about Endlinks, but bushings are. Mine are ISF bushings. Are you sure it's not the bushings making the noise? In my case, Endlinks were fine, it turned out to be the F-Sport bushings making noise (the crunching you are describing). Since I changed to the ISF bushings, no crunching sounds. Rear are F-Sport bushings because ISF bushings don't fit the rear sway bar, so I'll just grease them every year
When the bar was installed, I added synthetic silicone lube for poly bushings. If it weren't for all the stupid bolts holding the cover on I would have greased it, but the weather was a little sketchy.
For now I could toss the original links in to confirm the sound is gone. I love doing work twice! lol <- NO!
Thanks man...
AMIRZA786 (05-16-22)
#338
I popped the suspect noise side free and it felt like gravel. So, 99% certain that is most of it.
Thanks man...
Thanks man...
#339
Were these the original Endlinks, or did you change them when you added the F-Sport Sway bar? When I installed the F-Sport Sway bar I also changed the Endlinks (Stock OEM), but it's only been about year. Hopefully they will be fine as my IS doesn't get too much action these days ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Do you know which of these sets you installed?
#340
They were new as the OEM had 100k miles on them.
#341
We know people have installed the IS-F bar in there 350's. I wonder if they used the correct end links?
People that lowered their car would benefit from the shorter link as long as it doesn't bind up.
While I'm here. The upper A-arms are:
PN 48610-59065 RH
PN 48630-59065 LH
Lower Ball Joint:
43330-39625 RH
43340-39505 LH
Did you ever get the springs and shocks installed? I think the answer was yes....
#342
No worries. I have found the last ones listed are in fact IS-F. Two points of interest. They are shorter than ours and by the pictures appear to have 90° offset where ours have what looks like a 45/50° offset. Both cars use the same lower control arm PN 48620-53020 and 48640-53020.
PN 48610-59065 RH
PN 48630-59065 LH
Lower Ball Joint:
43330-39625 RH
43340-39505 LH
PN 48610-59065 RH
PN 48630-59065 LH
Lower Ball Joint:
43330-39625 RH
43340-39505 LH
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/1210x891/front_cd61c816839ad57c1fbc31276a798b65f00d9045.jpg)
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/1149x905/rear_106284669f9727fa26990d37577c71e8419649f1.jpg)
#344
