FSport's IS-350 running list of service & maintenance DIY
#496
11 year old OEM installed F-Sport spings have a measured ride height of 14-1/8" rear and 14-1/4" front as measured from fender lip to the center of the wheel (center of center cap).
Using these springs;
Front: Right 48131 / Left 48132
48131-53340, SUSPENSION-SPORTS&TIRE & DISC WHEEL-225/40R18+255/40R18
Rear: Right 48231A / Left 48231B
48231A-53280 SUSPENSION-SPORTS&TIRE & DISC WHEEL-225/40R18+255/40R18
Spring and shock listing:
AMIRZA786 (07-14-24)
#497
I have the "luxury" of rolling on max summer performance tires all year. Right now I'm on a set of BRIDGESTONE POTENZA SPORTs that done me well. First set of Bridgestone in MANY years...no complaints. Next will be a set of PS4s just chillin in the garage.
How has the Oregon summer been treating you this year?
#498
Also, I fixed OBD App by deleting it and sadly enabled more permissions than one should and all it well. Check out Tundra KCLV at 25.00... apparently that is a max. Anyone see this on the ISX?
#499
OG Member
To hot to ride the bike on the days I have off. Thats How it's been since day one of summer. AC in the 350 isn't as crispy as the Tundra, i see gauges connected to it before it comes out again. I wrote in the OBD Apps, Fusion thread, about running the wheels off it in the canyons, man that TCD thing in the back is a game changer! The limits are the tires now. Maybe I need some fat wheels (set #2), and summer tires?
https://www.clublexus.com/forums/bui...l#post10178366
https://www.clublexus.com/forums/bui...l#post10182705
#500
Is the goal with KCLV (Knock Correction Learn Value ), to keep the long term ignition correction factor / timing value under a certain value before the knock sensor detects a knock present in engine operation (for example: 15.4 below 3k rpm and 15.3 above 3k rpm, etc.)? Is it something similar to setting engine timing with a timing light to set engine timing (now controlled by engine ECU / or a tune)?
is350Speed
04-28-19 11:53 AM
runningox
04-05-09 08:10 AM
