Build Threads Details on Club Lexus SC owner vehicles
Kyles SC400T Build
Old 01-24-18, 04:04 PM
  #31
Kyleg250z
Kyleg250z's Avatar
Originally Posted by scsexy
wow.. I never seen an engine with so much rust inside...
What made you choose the uz instead of a 2jz? i've got my 2jz on 17 psi and i run out of gear not power around 150.
I have a straight 6 turbo already, I wanted a challenge. The V8 single turbo was definitely a challenge... lol
Originally Posted by kitabel
Very nice work, good luck with the build.
I hope you found a better .location for the alternator (shown in 12/22 9:01 PM), or used a heat shield - way too close to the exhaust. Even another 1/2" will help.
The exhaust is double heat wrapped. It is close, but its survived so far (maybe 10 miles and 20 dyno pulls?). There is no where else to put it, looking back I wish I'd made the exhaust a little further away. Clearance is just as tight to the power steering lines though.
Originally Posted by stkrmkr
Im glad youre staying with the 1UZ. It's too bad more people dont stick with it and build up a parts and knowledge base. By the way, my aftermarket transmission cooler was mounted to the front of my condenser.
https://www.clublexus.com/forums/bui...l#post10023146
Thanks for the suggestion, sadly I've got front mount fans and a front mount inter cooler. I wish I had the space to do fans like yours, pull always out performs push. I think my rad will struggle to keep up with the power I'm making with out adding any more obstructions. Side mounting inst the best, I think the fan will make up for the poor location though.
Thanks for all the comments and suggestions, its nice to be in such an active forum.
FMIC and Front mount fans. There is not much space to take a better picture
Insert trans cooler here:
Trans cooler and fan test fit, they have some space for airflow
My garage/shop is below 0C/32F, It needs to warm up before I go back out there.
Old 01-28-18, 05:24 PM
  #32
Kyleg250z
Kyleg250z's Avatar
It finally warmed up a bit, I got the garage up to about 17C.
Bits removed:
The goal was to install the new torque converter in the car. I removed the harness first, but the rear transmission speed sensor didnt want to seperate from the plug. I tried taking the bolt out to just remove the sensor, but it snapped from rust. After more struggling, the connector came off. For some reason this is the only rusted bolt on the transmission, the rest were serviceable just fine during the rebuild..
Drilling out the rusted bolt:
Tapping back to M6 and installing a new SS bolt:
Transmission out. It only took ~5 hrs this time vs 12 the first. The engine needs to be balanced on 2 car jacks, 1 at the crank pulley and one at the rear oil pan to keep it level. The transmission wont fit up nicely if you don't do this.:
Flywheel looks clean:
Level 10 TQ in!
Old 01-28-18, 05:33 PM
  #33
Kyleg250z
Kyleg250z's Avatar
I cut the dipstick off the transmission to clear my exhaust, and added a GM oil level sensor to make filling easier. Some how it didnt work, next up will be pulling the transmission pan to see what went wrong..
Old 02-08-18, 09:05 PM
  #34
Hankis
Hankis's Avatar
Wow I wish I had 2% of your talent. Just bought a 1998 Sc400. Getting it all sorted out. Look forward to what you are going to do next.
Henry
Kyleg250z (02-12-18)
Old 03-01-18, 01:43 PM
  #35
Kyleg250z
Kyleg250z's Avatar
Pulled the oil pan to diagnose the oil level sensor. ATF is weird, it passes through certain plastics (very slowly) which would hold motor oil fine. A cheap oil container is a good example, the ATF will slowly seep out. It seems the ATF permeated the GM oil level sensor I added. It no longer floats in the trans fluid and won't register a level. The sensor housing seems to be reacting too, its finger tight even though I torqued it down.
Hyundai temp sensor left (it was cheap), GM oil level sensor right
Ordered a Stainless Steel Duckbill level switch from Amazon, I think I can re-tap the M20 thread for the GM sensor to 1/2NPT if I use some sealant on the threads. The major diameter of the M20 is close to the minor diameter of the 1/2 NPT. There is no load or pressure at this joint, it just needs to be liquid tight. Hopefully there is enough room in the tube for the sensor to operate.
Old 03-18-18, 04:32 PM
  #36
Kyleg250z
Kyleg250z's Avatar
The sensor would not fit in the tube, I shortened it and TIG'd on a new 1/2 NPT bung
Replaced sensor with a sight glass, its at the same level the dipstick use to rest at
Trans cooler fan mounted up. There's a thermostat switch in line with the fan ground
Cooler installed
Dash cluster removed and sent out to Tanin for repair. The needles would stick and a bunch of lights were out.
Old 03-19-18, 06:56 AM
  #37
RudysSC
RudysSC's Avatar
Received 1,202 Likes on 833 Posts
You're a G Kyle - love seeing updates on this thing.
Kyleg250z (03-19-18)
Old 03-24-18, 10:11 AM
  #38
Kyleg250z
Kyleg250z's Avatar
Sight glass works perfectly, no more overfilling the transmission
Engine #2, or #3 if you count the one in the car...
This one was only 200$ because of the cracked oil pan. Good deal, I have a spare from the last engine.
Goodies are starting to arrive
Old 04-15-18, 04:38 PM
  #39
Kyleg250z
Kyleg250z's Avatar
Compression is good on this one, thank goodness. I'll lap the valves, that should bring up #3
Cyl# - Psi
1-230 5-220
2-210 6-220
3-195 7-210
4-230 8-215
All the goodies are in.
Moldy junk in the valley. Cleaned it all out and scrubbed it down with some kitchen cleaner.
Looks clean inside
Cams Out
Heads off
LEXXIUM (01-07-19)
Old 04-15-18, 05:18 PM
  #40
Kyleg250z
Kyleg250z's Avatar
The forum is being funny and not properly uploading the pictures. Will try again another day.
Hand sanding the block, to remove the last bits of gasket, the picture shows it about 1/2 done. The cylinder sealing surfaces look perfect. The rest of the block is super smooth, a finger nail doesn't catch at all. The discolored parts are from pitting, but it should seal up just fine. This is a budget build at the moment, there is no budget for machine work. If the block fails, I will machine and build the block coming out of the car properly and install forged parts and new bearings.
Valves are removed and the cylinder head is sanded perfectly flat too. There is some build up on the exhaust valves and exhaust seats, the intakes look perfect.
Old 04-15-18, 05:31 PM
  #41
Kyleg250z
Kyleg250z's Avatar
The car is running good, there are some issues I'm unhappy with:
-The 1-2 shift is far to harsh from the trans-go shift kit. All the shifts are harsh, but 1-2 chirps the tires badly past half throttle. This will be a problem, breaking traction at the drag strip. The solution will be swapping the 1-2 accumulator springs back to stock next time I am under the car, and re-sealing the trans pan for the fourth time...
-The car is lean at cruise - needs more tuning
-The trans fluid runs through the trans cooler, then through the radiator. The radiator is heating the fluid and causing the trans cooler fan to come on even when the car is idling not being driven at all. Solution: Bypass the trans cooler in the radiator
-Trans cooler fan was wired right to the battery, and can run after the car is shut off. This was a brain fart on my part, I've bought a relay to fix this.
Random log of driving around
Old 04-16-18, 07:33 AM
  #42
RudysSC
RudysSC's Avatar
In for videos here soon!!
Kyleg250z (04-29-18)
Old 04-20-18, 03:30 AM
  #43
Vitamin-SC
Vitamin-SC's Avatar
Kyle, "you are a Beast"!!!
keep up the good work
Old 04-29-18, 06:24 AM
  #44
Kyleg250z
Kyleg250z's Avatar
Took the car drag racing, it was very disappointing, 14.9 @ 105 mph.
There were a few problems, on crummy "Riken" summer tires, the car would do an 1/8th mile long burn out. When changing to slicks the transmission was having issues. THe stock ECU cuts timing during a shift, while I dont have that ability, the trans was not happy shifting under a full ~450hp, and slipped when engaging the next gear.
Last, I made a mistake taking forum advice and did not put an oil restrictor on the turbo. After a pass where I was banging it off the rev limiter for 2-3s waiting for the gear to engage, huge clouds of blue oil smoke appeard behind me. I removed the turbo, and the housings were both full of clean oil.
The seals look ok, I'm buying an overlapped turbine seal and an oil restrictor so this doesn't happen again.
Old 04-29-18, 06:31 AM
  #45
Kyleg250z
Kyleg250z's Avatar
I'm also making a transmission controller from scratch for race use only. The cheapest one online is ~500$, and it looks simple enough to control it. There will be a Relay to disconnect the factory ECU from the transmission, and allow for me to shift fully manually. The only downside is it is a "stupid" system and will not prevent me from choosing a wrong gear, for example first gear at 100mph...
If the relay's fail or are turned off, the factory ecu takes control back
Quick Reply: Kyles SC400T Build
