Rudy's SC300 Weekend Warrior
#316
We road race our SC300 bone stock with the open diff and it does hurt us slightly but really once you know how to properly set up for, turn in, and come out of a turn with the open diff it doesn't hurt you as bad as it would seem. We smoke some fast cars with factory lsd's so it's not all bad. Don't get me wrong, I wish I could run the torsen, but we manage without it.
silentkill (12-02-20)
#317
Well - Ryan (@scsexy) was kind enough to have me by to use their dynojet yesterday. I’ve been wanting to do this as a baseline and just out of curiosity with this wonderful engine. It was a nice chilly day and the car ran great! 2jzgte vvti with a FMIC, full 3” turbo back, intake, and basically stock otherwise as far as I can tell. It typically hits 15psi and I’m still running my w58 trans. The pull was done in fourth gear.
It made a healthy 370 whp and 446 lbft of torque! These numbers are corrected (we’re at a mile high up here and true numbers are a little sad lol). That’s about the power I was hoping for, but I can’t believe the torque!! With how far the fuel curve is there’s a lot left on the table. However, depending on how this year goes, I’d love to start with a standalone, get the most of the twins, and then eventually throw a “smedium” single on lol.
Hope y’all enjoy! I can’t recommend Ryan and the guys at Finish Line in denver enough. If you’re local and would like to make some dyno pulls give them a shout.
The following 7 users liked this post by RudysSC:
Bimmerbill (12-24-20),
KahnBB6 (12-24-20),
kakezzi22 (01-09-21),
KiroLS (12-25-20),
mrmj2u (12-24-20),
and 2 others liked this post.
#319
Rodger - the torque definitely caught me off guard haha.
And I definitely agree... I need to start doing a little research into something that’s plug and play with the aristo harness, or something with a nice adapter harness...
I think that’ll be my next project after the cressida runs haha.
The following 2 users liked this post by RudysSC:
Bimmerbill (12-26-20),
KahnBB6 (12-27-20)
#320
Two vastly different cars with two vastly different engines:
Installed these upper LRB (and lowers, not shown) cooling plates. Honestly, not super impressed with how they fit, but they will do the job.
The Cressida is coming along slowly, but surely! Full size LS radiator is in, intake, measure for driveshaft, etc etc. Still need to figure out wiring, fuel lines, etc. However, I can't help but smile when I pop the hood.
The following 6 users liked this post by RudysSC:
Ali SC3 (12-28-20),
Bimmerbill (12-30-20),
KahnBB6 (12-28-20),
Mike1JZ (01-11-21),
mrmj2u (12-28-20),
and 1 others liked this post.
#321
Had a local driveshaft shop make this up for the Cressida swap. They built it for a terrific price - removed the factory guibo on the LS side, and upgraded the rear joint on the Cressida side. This is officially the most expensive part on the car - I paid more for this than the car, and more than engine/trans swap lol. It was a whopping $550. Bills Englewood Driveshaft in Englewood CO is the absolute best if you're ever looking. It's overkill, for sure, but with the abuse this car might see from time to time Bill really sold me on the upgrade. Plus, I didn't even think about the fact that going from a 2-piece driveshaft in the LS to the single piece in the Cressida that the guibo with no ability to change angle wouldn't have lasted too long lol.
#323
Great move, should handle everything you can throw at it.
#324
Thanks Ali! I'm always pleased with Bill's work and am glad to have someone in town to trust.
Bill - you're absolutely right! We'll see how long that old solid axle rear end holds up...
#326
The Guibo is the rubber flange that bolts between a driveshaft and trans/diff. Typically only used in two-piece driveshafts due to the fact that one end of the driveshaft will no deflect. When going single the guibo had to go and the large aluminum CV section is in place of that so that it can articulate as the rear suspension moves!
The SC is going to need one of these next...
RudysSC (01-12-21)
#329
Ali - I believe the rear solid axle on the Cressida is very similar if not nearly identical to a similar era Toyota truck!
Silent - thanks man! But don't give me too many props... I bought it with my swap and it's definitely hydrodipped over plastic... haha!
silentkill (01-12-21)
