Build Threads Details on Club Lexus IS-F owner vehicles
Hurtado ISF Build
Old 01-25-20, 07:32 AM
  #256
HurtadoISF
HurtadoISF's Avatar
Originally Posted by Jwconeil
Im surprised you didn’t save more weight. I wonder if the detriment is the tire or rim weight. It’s crazy how much the same sized tires can differ in weight.
I think it looks much better.
the HREs aren’t a heavy wheel to begin with but even then the Bridgestone is a lighter tire I think 1-2lbs lighter also they are pretty worn compared to the new tires not sure if they had any noticeable weight difference
Old 01-25-20, 08:56 AM
  #257
Jwconeil
Jwconeil's Avatar
you have more tire height, more affordable tires, and their lighter. All wins.
Old 01-25-20, 09:07 AM
  #258
HurtadoISF
HurtadoISF's Avatar
also went from a 255 front to a 275 and did I mention the “275” AR1 is just as wide as the 285 re71r
Old 01-25-20, 09:43 AM
  #259
HurtadoISF
HurtadoISF's Avatar
285 RE71 compared to “275” AR-1
WillAP1 (01-25-20)
Old 01-26-20, 01:13 PM
  #260
Jwconeil
Jwconeil's Avatar
Can you share the tread depth, cost and where you got them? Tire rack doesn’t carry them. Those look promising and affordable. I’d be a bit worried on how they go in the wet.
HurtadoISF (01-26-20)
Old 01-26-20, 01:35 PM
  #261
HurtadoISF
HurtadoISF's Avatar
Old 01-26-20, 08:55 PM
  #262
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,964 Likes on 2,401 Posts
I said it on YouTube, and I'll say it here - buy the diff - Cusco or Giken - before you spend money on two piece rotors. I have RB rotors from Figs, and they're great with the HC+800 pads, but they didn't make anywhere near the difference the OS Giken spool made. It's like a cheat code for real.
The following 2 users liked this post by lobuxracer:
Bast59 (01-27-20), James7 (01-26-20)
Old 01-26-20, 09:14 PM
  #263
HurtadoISF
HurtadoISF's Avatar
thank you that’s what I am leaning towards honestly I plan on having both by summer but I’m definitely going with the diff first just need to find out how much install will be that’s what’s holding me back currently
Old 01-29-20, 08:49 PM
  #264
HurtadoISF
HurtadoISF's Avatar
Default Next up
Finally... A much needed LSD will be going in my 08 ISF after my next track day (don’t have enough time for break in)
MLRSTJ (01-30-20)
Old 01-30-20, 04:16 AM
  #265
Jwconeil
Jwconeil's Avatar
Who is installing? I swear the day is coming that I just say screw it and install one myself in my daily. Indy shops around here won’t touch it.
Old 01-30-20, 07:09 AM
  #266
HurtadoISF
HurtadoISF's Avatar
I called Cusco USA and they gave me the number to a shop in my local area that has experience installing their LSDs
The following 2 users liked this post by HurtadoISF:
Jwconeil (01-30-20), MLRSTJ (01-30-20)
Old 01-30-20, 11:50 AM
  #267
Jwconeil
Jwconeil's Avatar
why did you go with Cusco over OSG? Just curious.
Old 01-30-20, 11:53 AM
  #268
HurtadoISF
HurtadoISF's Avatar
I know the osg is better since it’s not as clunky but RR swears by the cusco and they haven’t had any issues plus I got it for $1,200 brand new off another member that never got around the installing it. But yeah mainly was I couldn’t pass up a good deal
Old 01-30-20, 01:33 PM
  #269
Jwconeil
Jwconeil's Avatar
Im sure the OSG is awesome, but honestly I think even the Torson does just fine as long as you have the right suspension. Any LSD is miles better than an Open diff.
Old 01-30-20, 02:47 PM
  #270
HurtadoISF
HurtadoISF's Avatar
yeah I can’t wait, it’s probably the first mod I should have done. I’m just waiting for my figs bushing kit. Will probably go in towards then end of the month.
Quick Reply: Hurtado ISF Build
