Build Threads Details on Club Lexus IS-F owner vehicles
Hurtado ISF Build
Old 02-16-20, 09:12 AM
  #286
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,964 Likes on 2,401 Posts
Originally Posted by HurtadoISF
I highly recommend it, with an fittings tho. I’m at the track now and no more CEL also it fills up after every session so it’s doing it’s job
I would do a leakdown test on the engine to see how well the rings are sealing. This result from the catchcan doesn't sound like a happy engine.
Old 02-16-20, 09:18 AM
  #287
Jwconeil
Jwconeil's Avatar
My catch can doesn’t catch anything. I have never found fluid in it.
Old 02-16-20, 09:48 AM
  #288
HurtadoISF
HurtadoISF's Avatar
would the leak down test be the same as a compression check? I have been wanting to do that
Old 02-16-20, 09:49 AM
  #289
HurtadoISF
HurtadoISF's Avatar
mine only does when I go to the track never when just driving normal, even when doing pulls on the street no fluid only when doing hard cornering
Old 02-16-20, 10:35 PM
  #290
HurtadoISF
HurtadoISF's Avatar
Improved my buttonwillow lap time from 2:11 to 2:05.04 only difference was 18s square set up with nankang AR-1 also, cooling upgrades worked great and so did the AOS with AN fittings no more CEL for air leak
Old 02-17-20, 07:11 AM
  #291
Jwconeil
Jwconeil's Avatar
Which specific fittings did you use? The above convo has me a little worried about air leaks, might as well bite the bullet and follow your lead. Thanks in advance!
HurtadoISF (02-17-20)
Old 02-17-20, 07:37 AM
  #292
HurtadoISF
HurtadoISF's Avatar
I went with red horse performance AN fittings, one of the guys on Facebook helped me with this one. These are the list of part numbers I used 👍🏼
The following 2 users liked this post by HurtadoISF:
Defratos (02-20-20), imp0rted1 (02-21-20)
Old 02-17-20, 10:54 AM
  #293
BirgeyT1
BirgeyT1's Avatar
Glad I could help buddy
Old 02-17-20, 11:02 AM
  #294
HurtadoISF
HurtadoISF's Avatar
thank you! I didn’t know your CL username but we appreciate it 👍🏼
Old 02-17-20, 01:11 PM
  #295
lobuxracer
Tech Info Resource
lobuxracer's Avatar
No. Compression tests can lie about things. Leakdown doesn't lie and tells you if your valves are good/bad or rings good/bad or both. Compression tests are not what you want for a performance engine. A leakdown test puts the piston near TDC, then puts air pressure in the cylinder and allows you to listen for leakage. You'll hear ring leakage through the oil fill, and you'll hear valve leakage in either the intake (not so likely), or the exhaust (a LOT more likely). You can also get a percentage measurement which tells you overall how well the cylinder is sealing so you can make the right decision about needing just valves or just rings or both.
The following 2 users liked this post by lobuxracer:
James7 (02-22-20), minator (02-18-20)
Old 02-17-20, 01:33 PM
  #296
imp0rted1
imp0rted1's Avatar
thanks for this.. my aos from RR never locked right from the start
The following 2 users liked this post by imp0rted1:
HurtadoISF (02-18-20), Jwconeil (02-18-20)
Old 02-18-20, 10:32 PM
  #297
HurtadoISF
HurtadoISF's Avatar
Old 02-22-20, 01:34 PM
  #298
HurtadoISF
HurtadoISF's Avatar
Another look at my AOS with an fittings
The following 3 users liked this post by HurtadoISF:
Defratos (02-22-20), Mr20v (02-25-20), WillAP1 (02-22-20)
Old 02-22-20, 01:42 PM
  #299
WillAP1
WillAP1's Avatar
Niiice! No pics of the trans cooler install though? Curious how you oriented some things.
Old 02-25-20, 11:19 AM
  #300
ISF4life
ISF4life's Avatar
Lots of progress since last time i saw u keep up the good work
Quick Reply: Hurtado ISF Build
