Vince's NA-T college fun build
#48
See thats the thing, the holes on the billet piece are smaller than the turbo inlet thread. Not only that but that billet piece has no thread in the middle due to the check valve.
#50
You can buy this and be done with it then: CLICK HERE
#51
Yes, you should probably replace the whole oil line kit. I was trying to help you to be able to use it (instead of telling you that you should’ve bought a “better” kit). I’m running a boostlabs oil line kit. It’s pretty expensive for what it is, but I have peace of mind cause my lines are of pretty good quality.
#53
Heres the turbo line
Its finals week so Im kinda out of it rn lol but yeah its journal bearing. Also, idea. What if I pick up this line(linked above) and since it connects to a t4 turbo, I can run it and cut the hose and connect the rest of the hose to the oil pan and oil line?
#56
this is what I’m running: LINK
#57
That line that you’ve linked is for a dodge and is natural steel so it will rust. You will want stainless steel braided an lines.
#59
