Build Threads Details on Club Lexus LS430 owner vehicles
YannG's 05 Lexus LS430 Build thread
Old 04-30-21, 09:08 AM
  #166
YannG
YannG's Avatar
hey guys!
I do think it would be great to hold an LS430 meet near/or around Atlanta - hopefully soon!
mavisky (05-11-21)
Old 05-11-21, 09:28 AM
  #167
rsvpdavid
rsvpdavid's Avatar
that looks like a LOT of work, but it looks GREAT!
Old 05-11-21, 09:30 AM
  #168
rsvpdavid
rsvpdavid's Avatar
the wood trunk custom looks great but doesnt everything slide all over in your trunk every time you make a turn?
Old 05-12-21, 08:20 AM
  #169
YannG
YannG's Avatar
Thanks for the kind words!
Everything is bolted down in the trunk, so nothing moves at all.
Old 06-10-21, 09:54 AM
  #170
YannG
YannG's Avatar
Default Update - Maintenance - Megan Racing RCA
Hello fellow CL members,
Hope everyone is doing well!
Little update - Did an oil+filter change, powersteering rack poly bushes, fitted some new Megan racing RCA and did my 3rd transmission drain/fill.
Next on the list is the valve cover gasket, I think the driver side one is slowly starting to leak!
(ps: special thanks to Dan @ theautolounge)
All comments welcomed!
Yann.
cqhall (06-10-21)
Old 06-10-21, 09:59 AM
  #171
mavisky
mavisky's Avatar
Whats the reason for all the transmission fluid changes?
Looking good.
Old 06-10-21, 10:15 AM
  #172
YannG
YannG's Avatar
Looking good.
Hey Mavisky - Really just a preventative measure, the car is over 200k and was recommended to have it drain/filled 3 times.
Old 06-10-21, 01:00 PM
  #173
Ellesse
Ellesse's Avatar
Yann.
nice update! I installed those same RCAs a few weeks ago as well!
Old 06-11-21, 04:04 PM
  #174
Kira X
美少女戦士セーラームーン
Forum Moderator
Kira X's Avatar
How difficult was the RCA install? I have a Youzealand SS Kit I need to install on my car.
Old 06-11-21, 04:56 PM
  #175
Ellesse
Ellesse's Avatar
It's very straightforward, this helped (the rca is a single piece here but same thing)
If you're running less than a 19" wheel though there might be a clearance issue
Old 06-14-21, 07:57 AM
  #176
YannG
YannG's Avatar
Nice work ! Did it lower your LS ? Lets see some pics
Its very easy, just remove the lower ball joint bolts and fit the spacers - just make sure you adjust the brake shield as it may rub on the disc.
https://youtu.be/ozx1c86JYDE
Thanks for posting that video!
Old 06-16-21, 05:58 AM
  #177
Wlpls430
Wlpls430's Avatar
Great write up! How hard was replacing the steering rack bushings? Basic tools only?
Old 06-16-21, 10:03 AM
  #178
YannG
YannG's Avatar
Thanks Wlpls430 ; Honestly kind of a pain! I had to use an air hammer - I would think using basic hand tools could be done, just be creative!
Yann.
Old 07-21-21, 11:49 AM
  #179
Pappadock6
Pappadock6's Avatar
I just read every post in this build thread. Amazing detail. I just got my 2004 LS430 UL couple weeks ago finally after wanting one for 20+ years! I am looking forward to enjoying it as is for a bit but a build/detail maintenance of some sort is coming. I may need to reach out to you for your guidance and expertise. I live in Atlanta area also. I also have a Hellcat Charger on bags so that is something I def want in the future.
Old 07-22-21, 02:12 AM
  #180
notmill
notmill's Avatar
I have the same ones on my car. Basic tools. A good set of offset jaw pliers might be good for pulling them out as the OEM ones are stubborn. I also needed an alignment afterwards.
Quick Reply: YannG's 05 Lexus LS430 Build thread
