01 GS3 Build
01 GS3 Build
I've owned this car for a few months now and I figured I should get a thread going. It'd going to be a slow one because I just went back to college, but I've got big plans for this car.
The day I picked it up in the fall
Threw on some ZEAL function T coils, I'm very impressed with these things.
Rolled and pulled to fit the 19x10.5 wedssports in the rear. Bad picture, I know.
GTE swap
I was originally planning to throw these on but I recently came across Cherokee SRT callipers for $150 and I couldn't say no!
HUGE! I ordered ECP brackets for the front, but I'll have to fab up my own for the rears. I have a fair bit of 3d modelling experience and I'm hoping to get some parts made up and get some brackets machined at work for the rear. More updates to come soon!
DISCLAIMER
Cherokee SRT brakes absolutely will not fit your 2gs. This idea was scrapped.
GTE swap
DISCLAIMER
Justmeez (05-05-19)
Yeah the rears will be a bit of a pain that's for sure lol. I sold the stock ECU and turbos, going for haltech elite and a BW S366 (or similar) for a pretty modest single setup for now. Eventually I'd like to get the car up into the mid 600 wheel area but for now I'd just like to get it on the road.
Can you link to where you bought the brackets and did the fronts bolt right up? I think the GS has less room for brakes because of the location of the tie rod compared to the Supra/SC. I've had my eye on those brakes
https://m.facebook.com/EximiousCustomParts/
We will see. To my knowledge nobody has done the brembo's before.. since I got them for so cheap I figured I'd try. They will require some shaving to fit and I'm not sure about the tie rods. I had to message ECP on Facebook to buy the fronts as they dont have a website yet. If the brackets don't fit I'll probably make my own to make the calipers clear the tie rod. Here are some links that may be helpful
https://www.clublexus.com/forums/bui...und-2-a-3.html
Progress is looking good but those calipers aren't going to work. I tried them already and there just isn't enough room. I'm assuming whoever made your brackets developed them for the Lexus SC300-400/Toyota Supra. The tie rod on those cars is on the front side, the tie rod is on the back (or caliper) side on the 2GS, IS300, and SC430. I have access to 3d modeling also and couldn't figure out a way to get it to work with 14.2" ISF rotors. I was using a 30 mm rca to push the tie rod down and it still wouldn't work with those caliper because they long and super wide. I later tried CST-V calipers.They are long but slimmer. I used a 15" RCF rotor and 40 mm RCA's to get the caliper as far away as possible from the tie rod. I actually had prototype brackets made but it still required either shaving the tie rod a lot or using super expensive Fig's hi-steer ball joints which don't bend up like the OEM ones. I scrapped that too and was about to give up on a semi-OEM option until suprastore came out with brackets to run LS460 calipers with 14.2" ISF rotors. Even that setup requires an RCA, not sure if the minimum size needed is 17 or 30 mm, but it works. Just need to shave the dust shield and buy better bolts because the ones Suprastore provides suck. Here is a link to a recent build thread that included that setup. I sold just the front two calipers for like $300+ on ebay so at least you'll make some money offloading them.
Well dang.. I really didnt like the supra calipers so I dont regret selling them. Do you think your prototype brackets for the 15in rotors would have worked with the figs hi steer kit? I'm not in a rush to get the brakes on, but I figure since I got such a good deal on them it wouldn't kill me to go that route. It would also reduce the amount of shaving necessary on the mounting side because there would be less interference with the knuckle using the 15in rotors.
As far as cost:
SRT calipers = $150 (smokin deal)
Figs balljoint = $450
40 mm Sage RCA = $200
Custom bracket = ???
RCF rotor = $130 each on rockauto
LS460 caliper = as low as $90 for the front pair
Suprastore bracket = $175
New bolts and nuts from the dealer = $30
ISF rotor = $90 each on rockauto
30 mm Megan RCA = $70
The more reasonable thing is to sell the SRT calipers and just do the LS460 setup. I do get that sometimes we just want to develop stuff like I did myself.
I haven't seen any updates on the rear brake setup.
captainva (05-07-19)
The brackets I had made were to mount 6 piston CTS-V calipers. If I would have bought the Fig's balljoints I'm pretty sure everything was going to clear when using the 40 mm RCA. I didn't finish that install for two reasons. I didn't like the idea of having to use specific balljoints that could cease production at any time. The bracket had some bosses on them that were pretty thin in some places and I just wasn't comfortable with that. With regards to the Jeep calipers, I'm not sure if the 15" rotor/40 mm RCA/ Figs's balljoint combo will work or not.
As far as cost:
As far as cost:
The more I look at the 460 brakes the more I like the idea. I've decided to sell the brembo's and go that route. For the record, I sold the supra brakes because the cardone reproductions were horrible. Half the pistons were too scratched up to use, and I took the calipers apart before I even put them on any car.
I don't have a Facebook but I'm pretty sure the same guy was a member on here (his car was black but I'm too lazy to go find his post). I asked him about it when he was having it done and he said some shop was making custom brackets for him and installing it for $2000. He didn't provide too much more info so I left it alone, especially since RCF calipers are expensive.
6 piston
http://www.a-r-z.com/Lexus-GEN2-GS30...-BBK_p_34.html
4 piston
http://www.a-r-z.com/Lexus-GEN2-GS30...-BBK_p_25.html
