Aussie 01 LS430 Daily driver
#61
Just saw this thread. Keen to see how the VIP bits from Japan go when installed. I like that grill. Did not realise how close to home other LS430 owners are. I'm in Bunbury and I noticed your hire trailer location.
I had the the exact same car (pre-facelft in the same ivory pearl colour) which I sold around 18 months ago to a fella in Mandurah. Have since upgraded to a silver facelift model last year which I'm pimping up. My VIP rims arrived just before Xmas which took 4 months from Japan by canoe so I feel your pain.
I also noticed that ad you posted for a wrecking LS430 in Perth from a couple of years ago. I reckon that's the same car I bought that front right fender from hence why it's missing
#62
Hi MacroP, how cool to find another LS430 owner in the south west! I really don't see many around but I always have a look if I come across one so would be great to check yours out especially with your upcoming mods. I bought my car from Mandurah but it was mid 2019
#63
well the car has been back from the panel beaters after being straightened out, I received it back like this whilst i am still waiting for my parts to come. looking nice and straight now! the new air con condenser is in as well and all hooked up so it will need a re-gas at some point
#64
Now I will do as much work as I can before parts arrive (they are actually in Australia now so not far off) last night I started with the broken relay/ecu boxes
ecu box was a straight forward swap, old vs new in the picture below
#65
the triangular relay box next to it however was a different story. this one here
the relays are mounted in this cartridge which comes out from the top
then the wiring from underneath is actually pinned into the plastic casing as one big piece
So I had to de-pin the wiring harness from the casing, taking heaps of photos as I went, a small screwdriver was all that's needed to de-pin
and the wires would easily slip out
old plastic case vs new
re-pinned exactly how it was (hopefully) and all complete!
ECU and relay box now looking nice and straight
JaySco (03-01-23)
#70
funcrusher (03-01-23)
#72
Well my package from Japan arrived today finally and I opened everything to check for any damage and had a play fitting things up
Grille
Rear spoiler
Grille
Rear spoiler
#73
I am not 100% sure about the bodykit just yet... I mocked up a few parts but was struggling to see how they would fit properly, its difficult to do in my limited space so I will leave it up to the bodyshop . I understand its not genuine parts and it was not a big $$$ kit so there may be a bit of work in doing the fitting up but I will discuss with the bodyshop and get their opinion and go from there
AngoLS430 (03-02-23)
#74
Today someone came and did headlight restoration on the new headlights, I also had the fog lights done at the same time whilst they are off the bumper anyway. they also did ceramic coating so that should help the finish to last!
Before
After, they are not perfect but any imperfections are on the inside of the lens which you cant do much about
The fog lights were heavily rock chipped so you can still see some of that, but still well improved
Before
#75
The headlights came up pretty good and a clear lens make such a difference to the car's appearance. A yellowing lens looks awful.
If they go bad again - just remember you can get replacement new lenses from Aliexpress for about AUD $200 for the pair. I'm about to replace mine as my lenses won't clean up like yours. The plastic is sort of milky not yellow. I've done a full wet and dry sand back and 2K clearcoat and they still look milky. New plastic lenses for me.
