bbyatv 1995 SC300 W58 Build
#46
#47
Added a Manual Boost Controller Today
I added a Turbosmart Manual Boost Control valve today. I made sure it was not a Chinese knock off. Took the boost from 8 psi to 11 psi. Feels good. Fun to drive.
mrmj2u (12-20-20)
#48
New Catch Can
This past weekend I upgraded my oil catch can. My old one was not getting the job done as I was finding oil in the intake tube leading to the turbo. I figured the old catch can was not cool (temperature wise) enough to condense the oil vapor coming from the engine prior to entering the intake tube where it was cooler. I decided to order a large aluminum catch can ($24 on Ebay) that I would install just behind the radiator where it would be nice and cool. I had to cut a custom hole in the radiator shroud to accept the new catch can.
I can remove one wing nut to pull the catch can and drain it. I can see the fill level tube on the side of the catch can through the fan shroud from the passenger side fender. Super easy.
I will update once I find out if it is doing a better job than the old one.
Here are some pics.
Bruce
Here are some pics.
Bruce
The following 2 users liked this post by bbyatv:
Bimmerbill (12-17-20),
mrmj2u (12-17-20)
#53
#55
#57
In the end, the car started on the first turn of the key, and runs like a bat out of hell. I kept it as simple as I could to ensure success.
Thanks so much for the compliment on her.
Thanks,
Bruce
#58
I suppose it was a combination of things. First and foremost, Ali recommended it for 2JZ-GE between 92-95 in the very first page of his NA-T ECU Mod post. It would have added cost, complexity, and time. I also wanted to keep it as original looking as possible while still having a turbo. I could always update later if I determine it is worth it. I probably would have had to get a different ECU and I wanted to run an TT ECU that was made for the same MY as the car (1995).
Thanks,
Bruce
Thanks,
Bruce
I think it looks even cleaner without the distributor but with a nice billet cover on there. I followed Ali's instructions for the is300 coil install and it works great starts right up every time.
#59
Very nice. I am glad to hear there is an easy mod to VVTI. If I ever decide to go higher than 14 psi, I will have to seriously think about it. Thanks for the heads up.
Bruce
Bruce
Very nice, if you do choose to make more boost and horsepower then VVTI coil are a good upgrade to prevent spark blow out at higher boost levels. I'm running Ali's TT ecu mod as well and make 500 wheel at 20 psi of boost.
#60
Harmonic Balancer Came Apart
I had my harmonic balancer come apart. As a result there was also some damage to the cooling fan. I ordered a new one (Power Bond PB1174ST) from Rock Auto and replaced it. I also had to make some minor repairs to the fan.
As you can imagine, when it came apart, it made a lot of noise.
Bruce
Bruce
