Here she goes in all her glory.....and only running on 6 cylinders (more on that later) a 96 coach edition I picked up for $300 car wouldn't stay running/idle unless your foot was on the gas pedal at all times. The interior was in decent shape besides the seat they were trash... More to come
Time for some cleaning the carpet was nasty! Luckily I have plenty of cleaner in stock do to having some furry babies lol.
Took the seats out and tossed them due to them being cracked/badly damaged. I found some seats in better condition at my local pullapart but they are grey.
These will have to due till I find some that will match.
Well i thought it was going to be a simple fix but came to realize im better of swapping the engine with something else.... So while I was trouble shooting the no idling issue I found a few problems....
Hhhmmm... lol Some research i found these cars are known for the engine harnesses getting heat stressed Corroded fuses And one of the dead cylinders no compression on both of them
Paper weight is out this thing was heavy and awkward to pull solo Listed it local and ended up selling the engine, trans, harness, and ecu for $300 the buyer had plans to use it as a mock up engine for his project he didnt care that it was hurt. this bay was filthy time to clean it up some Before After needs another pass or 2 with the pressure washer Also acquired my swap a 4.8 ls out of a Silverado
Found a 4l80e locally going to stay auto with this swap since it's going to be a daily driver. Engine is on the stand and ready for tear down then off to the machine shop it goes.
Engine is off to the machine shop to get honed and cleaned...in the mean time more parts for the build is showing up. Still on the fence about using the factory GM harness or getting a standalone unit with new harness. While im still thinking what route I want to take i decided to start the process of deleting pins i don't need and re routing the harness. Final result of taking out the unnecessary pins, rerouting some plugs, and branching off the "hot" wires for the fuse box i got. So the abs unit has to go so i can make room for the swap and possible turbo setup after the engine is broken in.
Engine is almost done at the machine shop so time to gut this thing for a rebuild. While i have everything out im going to do some test fitting (since the transmission case will be empty and easier to move) Mmmm yummy looks like some water got onto the pan More sludge Everything out of the transmission and laid out in somewhat of an order. On a positive note no sign of sludge in the case just in the pan and valve body.
Canton front sump oil pan is a must to clear the subframe. Thanks to summit for having low prices. Also picked up a compressor for the shop More cleaning
Got the block back had the machine shop install the crank, pistons, and bearings hear goes the first test fit with the canton oil pan Some areas i need to "massage" out lol Also picked up a tbss intake
Teach them while they are still young lol got the timing chain and heads on. Gitech throttle body with the tbss intake looking good. Need to touch up the timing cover and block with sone high temp paint. This is how far off it is from mounting up. Have some oe lexus mounts on the way for my slide brackets. 🤞 for some test fitting this week. Tunnel clearance for the 4l80e needs some massaging ⚒🔨
Not to much progress on the swap besides the mounts getting some hopefully final touches, but still have some decent goodies coming in enjoy.
New depo lights for the build So fresh and clean dang these are going to look good Also got some ame shallen wheels 18x8. Also got some megan coilovers Here is some progress on the mounts just have to get them fabbed up and some more test fitting.
Dang it's been swhile since posted... i started a thread over at ls1tech since no inetrest here... here goes the link i will try to convert it over to this thread soon https://ls1tech.com/forums/conversio...400-build.html
