Installing Vantrue Dash Cam
Which fuse I can use for my VanTrue Dash camera that as power when the car is off, that’s not the Cig fuse. Need someone’s help
fyi...if your used to Mini Fuses...our 3IS is micro fuses which will be better tapped with something like this:
Mini fuses is tightly put together as is and micro even more so and you don't want to just jam wiring up there
last post in this Thread:
DIY radar detector and Blackvue camera installation
https://www.clublexus.com/forums/is-...llation-3.html
best of luck and hopefully this is a BUILD thread but if not, they belong in the main sub section
check last post in Thread i linked, everything is there
