JT2MA71's 2014 UW build
#152
Give us feedback on those mounts.
#154
Interesting.... Aren’t you worried this might lead to increased noise and vibration? I would love to hear what @FIGS thinks about it. I just recently ordered these mounts, I was not able to put them in as of yet. Definitely looking forward to your feedback.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#155
BS ISF (01-28-21)
JT2MA71 (01-28-21)
JT2MA71 (02-04-21)
Joe Z (02-05-21)
Joe Z (02-05-21)
#161
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/42b7aca1_fc36_455d_b92e_2eee9c3ef3df_b5db0af5771e312a4834df564e498a583c9fa78a.jpeg)
All buttoned back up with new pan and bolts. I had fluid coming out of the overflow hole after pumping in just a little over 3 qts. I then pumped 2 more quarts in (probably overkill) to make sure I don’t have to undo the fill plug and add more when it’s time to set the level.
Joe Z (02-13-21)
#162
Tech Info Resource
lobuxracer (02-06-21)
