Nice, you did the steering rack brace. Did you do the steering rack bushings as well? FIGs sells stiffer ones.
If you took the car out, any noticeable difference with both braces?
I thought FIGS only have the solid steering rack bushings? I would have ordered the poly ones if I knew. I have been driving the car and I can tell there’s a difference for sure. Cars feels more solid during hard cornering.
Check the welds on your tips. I just lost on the other day, and the new one isn't welded any better. If I had a wire welder, I'd rework them since they only tack them in a couple of spots.
agreed, I was fitting a diffuser around the tips and broke the welds on one tip. Took them to my buddy's shop and he re-welded all the tips.
Good “tip” guys!
I actually did weld them in a couple spots
couldn’t get to the L brackets in between the upper and lower tips but I welded them best I can!
Daizen Sport Tuning makes poly bushings. What is wrong with the solid ones that FIGs offers?
Nothing is wrong with the ones Figs offers. I just prefer poly bushings. All the poly bushings I have on the IS F and RC F are from FIGS. I’ll check out sport tuning!
