Build Threads Details on Club Lexus IS-F owner vehicles
JT2MA71's 2014 UW build
Old 01-29-24 | 08:57 AM
  #571
iH8RICERZ's Avatar
iH8RICERZ
Thumbs up
Originally Posted by JT2MA71
Thanks! You will most likely beat me to it as far as dash install, I am having the new one wrapped in alcantara and the current one in the car does not need to be replaced
I always wanted to do this... love the texture and feeling of alcantara
JT2MA71 (02-15-24)
Old 02-15-24 | 03:23 AM
  #572
JT2MA71's Avatar
JT2MA71
Unfortunate thing happened while installing some VLEDS extreme LED front turn signal bulbs, broke my driver’s side turn signal reflector
Got two new headlights. Reinforced the bumper bracket mounting holes (these always deform when pulling the bumper cover off, causing the bracket to come loose, resulting in bumper to fender gap)
Made them out of titanium so they are very stiff while still very thin. Trimmed the bulb screws to keep them from hitting/breaking the reflector.
I will attempt to open up the headlight with a broken reflector and see if I could somehow make a new reflector for it. May have to do both headlights of course.
Broken reflector
Broken reflector
Old 02-21-24 | 04:41 PM
  #573
JT2MA71's Avatar
JT2MA71
Magnetic paddle shifters retrofitted.
The following 8 users liked this post by JT2MA71:
blckbrd (02-24-24), Defratos (02-27-24), forget2pee (04-10-24), iH8RICERZ (02-26-24), inovashn (02-22-24), roptic (02-26-24), Rossi (02-21-24), TallGoose (02-26-24) and 3 others liked this post. (Show less...)
Old 02-26-24 | 10:56 AM
  #574
roptic's Avatar
roptic
5th Gear
As usual, Nice job!
Can you provide me with info on the magnetic paddle shifters, where you order them from, and also if you don’t mind, info on your steering wheel
Thanks, Roy
Old 02-26-24 | 01:00 PM
  #575
JT2MA71's Avatar
JT2MA71
Originally Posted by roptic
As usual, Nice job!
Thanks, Roy
Thanks! paddle shifters are from MME Motorsport in Slovenia and steering wheel is from wovenChang on IG.
The following 2 users liked this post by JT2MA71:
roptic (02-26-24), valkISF (03-19-24)
Old 03-04-24 | 10:06 PM
  #576
ChpEng's Avatar
ChpEng
What are the advantages of magnetic paddle shifters? Curious.
Old 03-05-24 | 06:57 AM
  #577
JT2MA71's Avatar
JT2MA71
The magnets give the paddles a
more positive/tactile feel when pulling and when being released.
ChpEng (07-12-24)
Old 03-19-24 | 04:39 PM
  #578
JT2MA71's Avatar
JT2MA71
CCColtsicehockey (05-13-24)
Old 04-03-24 | 07:45 AM
  #579
JT2MA71's Avatar
JT2MA71
Frogdrive switch case, Sabelt steering wheel, Worksbell quick release hub.
The following 5 users liked this post by JT2MA71:
blckbrd (04-03-24), CCColtsicehockey (05-13-24), forget2pee (04-10-24), Positron (04-03-24), TallGoose (04-03-24)
Old 04-05-24 | 10:54 AM
  #580
Rossi's Avatar
Rossi
Ron, what setting are you running your Sikky sway bars?
Old 04-05-24 | 11:08 AM
  #581
JT2MA71's Avatar
JT2MA71
Stiffest, front and rear.
Old 04-05-24 | 01:16 PM
  #582
Rossi's Avatar
Rossi
Glad to hear, how is it? Any downside? Did you get a chance to try other settings and compare? I appreciate your feedback.
Old 04-05-24 | 01:47 PM
  #583
JT2MA71's Avatar
JT2MA71
Front, I haven’t tried the lower settings. I actually cut the ends and just left the last holes. Rear, I’ve tried the middle and stiffest and stayed with the stiffest.
Old 04-05-24 | 02:52 PM
  #584
Rossi's Avatar
Rossi
Thank you for the feedback, any downside to that setting?
Old 04-05-24 | 03:06 PM
  #585
JT2MA71's Avatar
JT2MA71
None that I've noticed.
Rossi (04-05-24)
