JT2MA71's 2014 UW build
JT2MA71 (11-29-20)
#79
@Jwconeil The IS F's from 2010 to 2014 came with 3 different Torsen LSD full carrier part numbers..
Your 2013 will be the same found on @JT2MA71 2014.![Big OK](https://www.clublexus.com/forums/images/smilies/bigok.gif)
41110 CARRIER ASSY, DIFFERENTIAL, REAR
1) 41110-53290
*FGR=47:16=2.937
(08/2009 - 09/2011) = MY 2010
2) 41110-53291 *FGR=47:16=2.937
(10/2011 - 04/2012) = MY 2011 - 2012
3) 41110-53292 *FGR=47:16=2.937
(05/2012 - 07/2014) = MY 2012 - 2014![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Joe Z
1) 41110-53290
*FGR=47:16=2.937
Joe Z
The following 3 users liked this post by JT2MA71:
#82
I like that mesh. Where did you get it ?
jdmek998 (12-04-20)
#84
M-D Building Products 57398... https://www.amazon.com/dp/B007JD4QSS...p_mob_ap_share
JT2MA71 (12-04-20)
#85
Tech Info Resource
Looks nice, but if you do this you will absolutely need to remove the bumper cover to replace the radiator. Without the fine screen you can get a long extension and remove the bolts holding the A/C condenser easily without removing the bumper cover.
Joe Z (12-05-20)
#88
Tech Info Resource
Did you check the vent to be sure it's not paint clogged? I think I would remove that if I were painting the cover.
#89
The condenser is bolted to the radiator in the front. No idea why, but a radiator swap is far more of a PITA than it should be. My Supra is stupid easy to do the same task. I routinely take the radiator out of it to clean out all the bugs and road grime.
I only spayed outside/around it and made sure I wasn’t spraying right up under the cap.
#90
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/f73513ce_ef41_4615_be4b_073a55dbaf8f_de82badc100e30934b5f0008c8a33f99099fa40b.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/346bc31b_7617_477e_b631_bd5664ae6ad4_5111c0aeb325754c00869945af10bdb2c2bcd7f1.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/f09ff091_aa87_4c12_925b_19250c15962d_053e391d631cf522284fc65822841e6420debb69.jpeg)
Had some time to install some ARP wheel studs. Had to trim them to get them in, without removing the hub. Also, used gun blue to apply finish to the hub flange and the ends of the studs. Paint just doesn’t work on the hub flange so hopefully the gun blue will last longer.
Joe Z (12-06-20)
