My 13' GS Base
#46
So this was a 2013 base? It’s been updated so well I can’t even tell.
I’d like to do the headlight and front bumper conversion.
And the steering wheel and 360 camera update including of course the newer infortainment
#48
I said it in a previous post, but again this GS build is priceless. Two questions if you would please? Is that really the Base or the GS350 Lux car and package. The Rear entertainment says GS350 Lux. Or did you add that too? I did not see that upgrade in you list of upgrades?
The J Pipe in the exhaust was a excellent way to cut Drone. I'm surprised so many just live with annoying Drone and try to play it off on a Luxury Sports car as if it's not a issue. Do you have a underbody pic of you Exhaust and the J pipe? And/or can you give some details about it, like exactly where in the Exhaust did you put it? How long of a J Pipe did you calculate using to stop the Drone? Is it gone completely? Thanks!
#49
I put 18'' pipes on the muffler. The J pipe can only eliminate around 70% of the drone or maybe I did not find a right length for it. Also the tone was changed a bit with j pipes.
Vorsteiner vff107
20 x 9.5 +35
20 x 10.5 +38
Michelin AS sport tires.
Thank you! It was a base gs with lux package.
Spartan09 (12-10-21)
#52
Incredible GS. Can the 360 camera system override the screen automatically when you put the car in reverse and stay on while at parking speeds like a factory bird's eye setup? I'd love to see a video of that if so.
#53
4GS350 (12-25-23)
#54
Thank you! Yes the 360 camera will automatically turn on when I put in reverse just like factory back up camera. Here is a quick video I made for you.
https://youtube.com/shorts/cInBrviF994?feature=share
#55
Indeed a nice build which must have taken quite a bit of time. Two things if u could assist, can u briefly describe the process of upgrading the nav to 2016+, along with the aftermarket 360 camera. Lastly, is it doable to upgrade gauge cluster to 2016+? Since I don't see u did this along with many people having this issue I assumed it's not doable without error codes.
https://www.clublexus.com/forums/gs-...-2013-gsh.html
Technically it is doable to upgrade the cluster to 2016+ but you will need to know how to hack the canbus to trick the 2016 cluster because there are so many warning lights after you plug it into the car. I tried and could not make it since it required to much time and effort.
#57
sertimins
01-22-21 05:56 PM
MrMark
Lexus Vehicles Classifieds
05-27-14 07:04 AM
montgb
11-12-11 11:23 PM
