2019 GS350 F-Sport Ultra White Build
Oh yea the figs are definitely stiffer than stock, from what I hear they are a tiny bit softer than the RR-Racing ones but 10 times easier to install since you dont have to the play with the preload like on the RR-Racings ones. I got the figs because it was just a simple straight swap and hear over time the figs squeaks less. I ended up having my alignment shop install them for me, I ended up not having a socket big enough to take one of the bolts out and the shop said it was like $100 to get both installed and for that price I had them do it so I don't have to mess with it.
Big day today. Weather was decent enough for me to go ahead and steam roll putting in the RSR coilovers, SPC camber arms, and the new vossen wheels. Also had my tires mounted by a mobile tire installer this morning as well. Set everything to recommended height settings by RSR and adjusted dampening control right in the middle at 12 out of 24. So far it looks pretty good, Ill need to lower the front a tad more to match the rears, the rear sits perfectly with roughly 1 finger gap or a little less. Obviously still a ton of rear camber but I'm not rubbing a single bit, hopefully it will stay that way after an alignment next week.
Car came out AMAZING!!
Question, for the puddle and trunk lights, did you use the 26 or 14 led bulb?
And for the sun visor you used the end fire one right?
https://www.vleds.com/shop-applicati...erior/194.html
Just want to be sure and order once.
Thanks
Thanks
Thanks
Thanks
Have not had chance to install the puddle lights but had no issues with trunk install. I also did the V6 bulbs for the front turn signals.
advan34i
Lexus Vehicles Classifieds
07-09-15 10:04 PM
