Purchased a 2006 IS350 from Copart. See the progress of the build. (Trust me)
#31
phone number is 818-620-9925. If you go out of trouble to make it here and buy I'll give it to you for 50
AMIRZA786 (11-10-21)
#33
First remove the driver side door sill (so screws its just clipped)
Same here remove rear door sill
Peel back the window seal from top of the B pillar all the way down to the end of the center plastic trim
Remove the black trim (no screws just clips) may take some fidgeting to remove it
Once you remove the black trim 2 screws are reveled, remove the screws to release the B pillar
Then at the center remove the bolt cover and remove the bolt that secures the bottom of the belt then once the B pillar is removed, put the seat belt through the pillar and remove the pillar
PewPew7 (11-10-21)
#35
In order to remove the B pillar (where the seat belt is):
For the rear pillar again peel back the window seal and use ur hands or a flat screw driver to unclip it and pull it back, once you put the new one in make sure the end clip goes through the hole, then rest just snaps on.
#38
F sport shift **** to match new armrest
I really don't wanna sell my current shift **** because it just looks better than stock but the blue stitching on the f sport will match the car better and since I'm getting a carbon steering wheel it will match that as well, anyways, order is in!
Gonna Twist it a bit more than this to make it sit lower, still doesn't look as good as the one I'm selling (imo)
#39
Installing ISF steering damper
So today I finally installed the ISF damper that reduces steering vibration and adds a tad bit of weight. Only the ISF and the ISC models got this. I'm gonna do a test drive with this before I do the ISF steering ecu mod to see a good differance. Will update.
AMIRZA786 (11-13-21)
#40
The biggest change is going to be weight, and inhibiting of undesired movement by adding steering resistance. That is helpful on uneven roads
Badboye (11-15-21)
#42
F sport Shift **** and new trunk mat
New shift **** and trunk mat finally came in, here's the results ...
I went ahead and screwed the shift **** all the way in to give it a low profile look, dont like the oem height.
New carpet looks good with the oem first aid kit that i also got with the carpet
AMIRZA786 (11-25-21)
#44
Oh sir I'm glad you did, I have a lot of parts being imported, you must stay tuned until the end of January when I say I'm building a one-of-a-kind I am! appreciate looking at my thread
