TIme attack sc400
#61
Here's a video i put together specifically for Thunderhill Raceway West course.
https://youtu.be/xHE2zjlTH-I
I'm thinking of adding a lip to my 92 front. How much does yours, do you think, add to your performance
Purple Bullet
bboyjohn04 (03-07-22)
#62
How much do you think your aero is helping vs hurting on certain tracks? Would be interesting to see lap times on the same track with the rear wing removed. I'm not familiar with Thunderhill, but looking at that video it looks like it could go either way. Lots of fast corners where it should help, but also induce drag and keep overall speed down on the straight sections.
And what's rubbing?
And what's rubbing?
No aero on bbs rs2 and federal rsrr setup
After aero, the added aero made the tires more usable after a few hot laps because it didn't get as oily keeping the car more planted on high speed corners vs the car wanting to slide around without the aero
#63
honestly i cannot say how much performance increase you will gain from just a lip. You would have to go and test your car on the track and gather data and compare the driving experience. I used the lip from kbd because i couldn't find any fujin lip available. Then i built the front splitter based on it to get the rake angle. However adding a lip in general will enhance the car aesthetically.
#64
Thank you,
I saw how much time and effort you put into the lip and front end, that was impressive. I have the front end I want, just have qualms about disturbing the air flow w a lip. I will do as suggested, take it out and see how things go
your time attack looks like a lot of fun. Stay Safe!
bboyjohn04 (03-08-22)
#65
Track Photo dump of my Time Attack sc400 from recent track day. Will go back to the drawing board and make some minor change for the front splitter to get a raking angle of attack.
Front view of sc400 with carbon creations ts1 hood and kbd lip along the custom front splitter
Big country labs 1850mm carbon fiber atmospheric demolisher gt wing
Time attack sc400 Side profile Te37sl
Probably my favorite shot of the time attack sc400 build and process.
stheodore (12-04-22)
#66
Congratulations on following your vision dude! I’m sure there was more than a couple doubters who told you the car was too heavy or whatever, but you persevered. Car looks great and it seems like you’re having a blast! What more could you want, right?
Nick
Nick
bboyjohn04 (03-12-22)
#67
more track days are what i want lol. I'll continue to update as i go. I'm really surprised that there aren't that many time attack or grip focused sc400 given it's front mid engine layout, it can be a very formidable foe in dogfights during track days. Hopefully more will join the scene
#68
My car weighed 3,683 without me in it and a full tank of gas, fully stock. Could we shave 700 pounds from this platform?
Nick
#69
Yeah, I think the SC has a reputation for being over-engineered and heavy. Weight is the ultimate killer in racing, as you well know. I personally hadn’t considered using the SC for track duty because despite its midship layout which you accurately point out, I doubt you could get an SC down in weight enough to make it truly competitive. Having said that, there’s a lot to be said for just enjoying your car and having fun, which I genuinely commend you for. I would love to see if you could get her down to 3,000 pounds. I think that’s kind of the threshold for a “lightweight” car. Sub-3,000 is where it’s at.
Nick
Nick
Autobahn Carbon
#70
yes weight is the enemy. In time i will start to tear down unnecessary components for strictly track purpose if i no longer want to keep the car registered. I'll continue to chip away. I continue to look at this car for inspiration in the platform to one day reach my goal which is to get to the point where the vehicle will be good enough to join global time attack events. The current power rating of the later 1uz vvti makes 290hp-300hp out the box but i think without a limited slip differential the car isn't as aggressive as i want it to be right now in terms of hard exit accelerations. I'd love to consider a manual conversion in the future which will probably be one of the biggest improvements. For now I'll continue to make small improvements and share the process.
Autobahn Carbon
Autobahn Carbon
bboyjohn04 (03-13-22)
#71
I have my 92 300 down to 2930 full of fuel but my buddy is at 2800 in his 300. I have a really heavy cage in mine with nascar style bars on both sides as well as .120x 1.75 cage material so the cage is approximately 150 pounds. The first 500 is easy pickings, but from there takes a lot of work for small gains.
#72
Nice thread, thanks for the pics and details. You have done a great job on the car. Look forward to more details as you make further improvements.
The following 2 users liked this post by RXRodger:
bboyjohn04 (03-14-22),
perfctreig (03-16-22)
#73
Absolutely love seeing you get out and enjoy this thing on track. Nothing like seeing a big girl out there doin her thang
bboyjohn04 (03-16-22)
#74
Next mod, deleting the sunroof/motor and headliner assembly. From what I've read from another build thread via (RxRodger, Thank you for the detailed thread) seems like the weight can be 33.4bs can be shaved from the top which can be some benefits to make the car somewhat more lower center of gravity to improve balance. Not huge margin but as mentioned before, i would like to continue to chip away on the weight. Also considering a manual quick ratio steering rack replacement from grannas racing (27lbs) can be shaved on front end. Anyways, goodies from LRB speed, im sure i could have made my own but these came with stickers plus supporting small businesses.
LRB speed sunroof delete cover
Borrowed pics from their site. Will go with the 14:1 as opposed to 20:1 for steering ratio since this isn't a drag car.
$1250.00 for the setup.. to spend or not to spend? 😅
Barbary (03-16-22)
