@Lex_Giorgio Thank you, no issues so far, haven't put on too many kms on them. Feels the same as stock, a tad bit stiffer but handles better and the ride is more planted. Will be switching to RSR coils though, I want the ability to adjust ride height more precisely with some better performance and dampening. Thinking of adding Stance Air Cups to be able to clear bigger speed bumps and steep driveways.
CF wheel installed. Threads on it didn't line up properly no matter how many adjustments made. Had to adjust the toe angles and now it's running perfectly straight.
Full carbon fiber oem trim pieces. Replacing the stick on pieces, the fit is much better and eliminates the small gaps between the oem trim. Got them from Elvin CF on IG. The center console pieces make a big visual improvement in the interior, looks really good.
Picked up these gloss black triple beam fog lights from @grey_3is on IG. A bit pricey but worth it, brings the front end together nicely. Also installed the sequential DRLs (non RGB, not a fan of the rainbow start up animation) while the bumper was off 👌🏻
