2002 LS430 Electrical Issues
8th Gear
Was having issues with many indicator functions on dash and with the trunk opening and closing in rapid succession. Fuse/circuit panel in trunk was damaged by moisture which had gotten into the trunk via a broken tail light assembly (now replaced). This resolved some of the issues on the panel however, trunk will not engage opening function, both little release motor and solenoid are fine, just not getting command signal from key or release lever by "left knee". Also, now fuel indicator reads below "E" and low fuel indicator remains on even though tank is full plus "Range", "Miles Since Fill" and one of the other functions isn't working either. Any ideas on what chase next? Don't know if there's more moisture somewhere or a command module somewhere causing the issues. Thank you, Lee
matchflick
02-10-24 12:42 PM
TFBTRADE
01-03-23 12:49 PM
