Just got a GS and there's a few questions i need help!!
I was wonderning if there any fix for the dashboard noise like the ticking noise when you go over bumbs and stuff and also i have a 2006 gs300 awd what is the KM per liter or Km per tankyou should get out of a tank i don't speed or anything i just drive normal.
thank you fellow members!!
the fix for your dashboard would be for you to find exactly where the tick is coming from over bumps... so push on panels until it stops making noise over bumps... then remove that panel and everything it takes to get access to that panel, and insulate the pieces and their mounting points with noise silencing adhesive foam or felt...
or take it to the dealer... they've got the most experience dealing with those noises...
now coz mine is already over the warranty are they gonna charge me or is something they already know there is a issue and they will fix it with no charge?
Jay hall
10-12-10 12:43 AM
