Lexus CPO purchase from GTA dealer is becoming a headache
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Bought a Lexus CPO 2013 GX460 from one of the biggest dealer in the GTA. Salesperson said it has gone through LCPO and yet the car has scratches and a dent when we test drove it. Salesperson said all will be taken of.
When we picked up the car, we found the dent fixed but can clearly see where it was touched up, and none of the scratches were fixed. We also found some underbody damage in the front that we didn't notice when we test drove the car but can be seen in the pictures in the ad. One of the remote controls was low in battery. Dealer agreed to fix everything while we went on vacation and we dropped off the car before we left. Before we dropped off the car, we also told the salesperson that the car appears to be pulling to the right and asked that it be checked out.
We picked up the car after vacation and found that the car was still pulling to the right. We also found that the scratches were still not fixed. Upon closer inspection, we also found all four hinges of the rear hatch to be rusting. We were told to drop it off, again, now for the second time.
So today we picked up the car and it seems to no longer pull to the right. The hinges are still rusting and the scratches - seems like someone just liquid paper over them! In fact, it looks like the guy didn't even wait till it dried and some of the touch-up paint has transferred over onto the weather-stripping. At this point, I am not sure what else I can do. This is ridiculous!
Received 1,735 Likes
I'm guessing the GX has the pearl white paint...looks like they put the base on but didn't put the clear coat, as the clear has the pearl finish in it...otherwise the base is just white paint.
I was trying to guess which dealer...if it was biggest dealer by annual sales, then it could only be DVNL. (I don't need to know, I just like a good mystery)
Honestly I would go to the General Sales Manager with your concerns...they are responsible for the New car sales manager and Used car sales manager.
GX is not a cheap truck and there is a lot of room for markup...so fixing those minor defects properly won't dent their bottom line.
The problem with pearl paint is that blowing in a section is not possible...it would never look right. You would have to blend the paint at least across a major panel in each direction of the area that needs correction.
mattau (06-04-17)
My CPO GX also had touch up done in Starfire Pearl... not as prominent as the OP's, but my dealer also used just the base coat... they were clueless about the 3 stage paint... base/pearl/clearcoat... (Roseville CA)
I know this doesn't help you, but you should have had them fix the problem areas BEFORE moving forward with the purchase. The dealers will tell you almost anything to get the sale, regardless of their intentions to actually remedy the problem(s). They will take the easiest and least expensive way possible, even if isn't the "right" way to do things.
If you make them fix things before the transaction - it's THEIR problem. If you try to get them to fix something after the paperwork is signed - it's YOUR problem.
They will keep jerking you around until you give up and/or too much time has passed for you to have any recourse. Escalate to the dealership's GM as soon as possible. Certainly be professional, but don't be afraid to use comments like, "this isn't what was agreed upon, perhaps I should pursue returning the vehicle for a full refund" or my favorite, "what would you do if you were in my situation? Would YOU accept this if this was a car you just purchased?"
Good luck!
Good luck!
mattau (06-19-17)
Good luck!
Good luck!
a quality lcpo inspection is suppose to be free of any aftermarket parts/scratches/dents/damage. if any, it fails on the spot. we do write it down in the system/notes for the ucd to fix, we dont know if they fix them or not, but we cover our own backs. anything else that wasnt done is usually from ucd.
Were you given the L/Certified Booklet? Inside the front cover on Page 1 is the line "Certification Number".
If it is blank you must insist on seeing the actual documentation and getting it. Without it your new wheels
is just a nice used car with balance of factory warranty...
Lexus Customer Satisfaction Department Canada number is 1-800-265-3987
I didn't get a booklet and no I don't have the number but when I spoke and in my written correspondence with Lexus, they do have my car registered as LCPO.
taimysho0
RX - 4th Gen (2016-2022)
15
08-16-19 07:45 AM
Dmaxdmax
08-02-18 08:11 AM
nharish
ES - 5th Gen (2007-2012)
26
12-03-08 06:18 AM
