Rear Inner Tire Wear
Note: I did post this one the 3IS forums to see how I can correct the rear inner tire wear, but my concern here is what you guys think of the condition of said tire; should I take their word and replace?
So I’m kinda scratching my head on this. Came to Discount Tire to fix a flat (which turns out the nail hadn’t even gone through) and balance all 4 while I was at it, and turns out my 2 rears are having inner tire wear. The drivers side isn’t bad but the right side is getting bad and the DT employee told me I can probably get 200 miles at most safely out of them. Was not expecting this. What do y’all think? I had the car aligned with 200 miles because the wheel was off center and the verdict was that the right rear toe was out of spec, but now that is the tire wearing the most…
I should add that I am currently at 13,800 on these tires. Admittedly I’ve gotten more out of these tires than I expected. Also, the lighting in the picture doesn't help because the 7PM sun is making the inside face of the tire look golden which some may confuse as cords or the like. I have 0 cords showing and I still have a tiny bit of the groves on the inside face, it is just definitely wearing down on the inside portion. The 3 outermost sipes are at 5/32" and the innermost is at 4/32" which is why I feel like I could get another 1-2000 out of these tires.
probably need to get your alignment checked, you may have a bit too much negative camber. Are you lowered by chance?
Also, if the tires are not directional (doesn't look like they are), you could have them re-mounted on the opposite wheels (don't just swap wheels) so that the outside shoulders become the inside.
