rusted Steel brake pipes(lines) leaking need advice?
#31
Really, it is. Lol
What are your thoughts on aluminum?
I think steel is stronger of course but can aluminum lines be used in a car?
I swear I saw stock lengths of it at the auto part store with the fittings already on them, just need bent to shape.
But maybe I was wrong and they weren't aluminum, have no idea now and 2nd guessing myself. Lol
#33
It's so easy a caveman can do it.
Really, it is. Lol
Really, it is. Lol
Nicop lines form easily and I've tried them but they do not hold up as well as a coated steel line long term and stainless beats them completely. I actually did an experiment in my Jeep and ran a coated line to the left front, nicor to the front right, and stainless on the rear and rear axle to see what happens when in a car that is never washed over 5 years.
The stainless is unchanged, like I put it on yesterday and the coated lines are nearly the same. The nicor has some surface pitting and discoloration and of the three did the worst. None failed though so all work but 305 stainless is on another level vs everything else. Makes sense since copper absolutely hates salt
#34
Nicopp is what all the local off-roaders use for modified brake lines - which is to say all new ones, as most of the time the only thing left from the original vehicle is parts of the cab and the subframe - usually around the VIN :P
Can't say anything about durability - haven't heard of any issues, but this is on... vehicles... that are looked over very often and are not driven a whole lot in general.
#35
Can't say anything about durability - haven't heard of any issues, but this is on... vehicles... that are looked over very often and arenot driven a whole lot in general.
#37
I'm guessing a Nicopp is a nickel copper alloy as posted above.
Guessing that gives it some extra strength and added corrosion resistance.
Ideally for DIY, it would be preferred to have a material that can be hand bent as needed with a cheap $5 tube bender vs having special tools.
I've done some flaring in copper a few times years ago, it was easy.
#38
#39
#40
#41
The coated steel I use is a ***** to form though, double flares have to be done very carefully/you need to know where to go past where you are supposed to in the dies and the "feel" for it even with a hydraulic ram forming tool. I'm used to it but I took me like 12 fittings to learn how when I started years back
The nicor stuff can be done with manual tools with extreme ease. Stainless also requires the hydro ram and care but it's insanely durable, my truck is equipped with stainless lines that took me about 40 hours to make since I wanted them absolutely perfect.
#42
Thanks for the suggestion,unfortunately city town mechanic,
doesnt have machine and tool, and the shop which have machine can work with aluminium or only copper brake lines nothing else, they have no other material or options unfortunately.
I found 1 company in europe, which can make stainless steel lines, but my car is 30years + old and left hand drive and they make for right hand drive cars only i emailed them, hopefully if they can make for my old rusty bucket stainless steel + teflon coating brake lines they will last at least 10 years hopefully.
#43
One thing you need to comsider is that there's no point spending money on brake lines that will last at least 10 years if the rest of the car might not last that long. You say it's a 30+year old rust bucket, in which case you need to think if it's worth it to keep throwing money at it, as dealing with corrosion issues can be a never ending series of expenses.
most parts was renewed
brake calipers,suspention, exhaust system, everything was well serviced and maintained, unfortunately brake pipes and fuel lines was not changed i do plan to drive car in the next 5-10 years if possible even more.
I dont care much about visual corrosion but i cant drive car without brakes, if air get traps inside i will loose ability to stop.
Currently used Car prices are very high high , i plan to use my rust bucket as daily driver for long time and to drive my hail damaged car after repair for long trips .
Rusty bucket is converted to lpg so its cheap to drive it, hail damaged lexus will stay on petrol forever.
Ag02M5
Maintenance
08-12-03 07:14 PM
