Two GR Corollas Burned Down. Toyota Won’t Honor the Warranties
Old 08-09-24, 01:32 AM
  #61
Motorola
Motorola's Avatar
Originally Posted by LeX2K
GS200t uses the 8AR-FTS no? This engine is still around.
It was removed from the GS before Lexus axed the vehicle. The only car left that still has that engine is the IS/RC300 which is as old as the GS. It's been replaced by the T24A for the rest of the Lexus lineup.
Motorola is online now
Old 08-09-24, 02:43 AM
  #62
Received 3,020 Likes on 2,536 Posts
Interesting didn't know it was phased out that quickly. 2AZ-FE or 1ZZ-FE is the worst Toyota engine IMO although admittedly i don't know much about the 8AR-FTS I do know it has 3 thermostats for some reason.
LeX2K is offline
Old 08-09-24, 02:49 AM
  #63
Lwerewolf
Lwerewolf's Avatar
2ZZ-GE is better than the 1ZZ-FE?
The normal ZZs are quite fine, assuming that you haven't driven them with trash oil.
Lwerewolf is offline
Old 08-09-24, 02:54 AM
  #64
Completely different engine.
They are most certainly not quite fine I've re-ringed at least 5 of them myself the early ones burn oil like crazy. With proper ring land holes the engine is good but that doesn't help people with oil burners. At least they don't catch fire that is literally job one of any engine, don't burst into flames.
LeX2K is offline
Old 08-09-24, 05:55 AM
  #65
Received 1,238 Likes on 922 Posts
The 1ZZ is perfectly fine, its replacement not so much....and the newer ones are even worse.
Striker223 is online now
Old 08-09-24, 05:59 AM
  #66
Just decarbon them and tell owners to floor it when the oil is warm once a trip. Cured 4 cars for customers so far without having to do the nonsense of a re-ring, all 4 now make full oil change internals without needing to add oil. The small ringland holes and lazy owners who never floor it or change oil/throw cheap oil in is not a design issue IMO....
Not using an engine to capacity causes issues, and I see it the most with Toyotas because people are apparently afraid to break their unbreakable ultra reliable car by operating it within design limits?
Old 08-09-24, 06:24 AM
  #67
Lwerewolf
Lwerewolf's Avatar
Agreed. I'd be worried about the C5x transmissions on these more than anything.
Old 08-09-24, 08:11 AM
  #68
Margate330
Margate330's Avatar
Received 1,018 Likes on 810 Posts
Do we know for sure neither of these two cars were modded in any way that could cause the fires?
Margate330 is offline
Old 08-09-24, 08:39 AM
  #69
Received 2,751 Likes on 1,968 Posts
Toyota would have cited that in their response since it would have been an easier out. Way easier than claiming it was because they drove 114 MPH once.
SW17LS is offline
Old 08-09-24, 09:01 AM
  #70
AMIRZA786
AMIRZA786's Avatar
Received 2,205 Likes on 1,715 Posts
Personally I don't think denying warranty or warranty is even the issue here. If it does turn out they modified the engine in any way, then Toyota would have the right to deny the claim. So far that doesn't seem to be the case, as it's not mentioned in the letters, and Toyota would mention this in the letter as the main reason the warranty claim was denied. Secondly, I'm not an expert here, but I don't think it's an engine defect, but more the case of an underbuilt engine. A way underbuilt engine. I've tuned a few cars in my day, and I have friends who also tune, and as long as you don't exceed the "overhead" built into the engine and properly maintain the engine, then it shouldn't blow. In the case of the GR Corolla, it seems that the engine doesn't have much overhead, and Toyota went cheap.
When I say built, I mean using forged pistons and rods, oil coolers, bigger intercooler, diff coolers and a robust cooling system. Doesn't look like that was done here, my feeling is Toyota went cheap, and now you have two blown GR Corollas that we know about. I'm interested in seeing how Savagegees's GR Corolla holds out, in their case they are heavily modifying it
AMIRZA786 is online now
Old 08-09-24, 09:57 AM
  #71
G16E-GTS engine has forged rods and crank with typical cast aluminum pistons. Block is a 3-piece design not sure how I feel about this. Engine is making 100hp per cylinder that's pushing things especially since the block is an open deck design.
LeX2K is offline
Old 08-09-24, 10:03 AM
  #72
AMIRZA786
AMIRZA786's Avatar
G16E-GTS engine has forged rods and crank with typical cast aluminum pistons. Block is a 3-piece design not sure how I feel about this. Engine is making 300hp per cylinder that's pushing things especially since the block is an open deck design.
You mean 100 HP per cylinder
Old 08-09-24, 11:03 AM
  #73
Lwerewolf
Lwerewolf's Avatar
Plenty of those engines in the Yaris, haven't heard of any serious issues. P.S. the G16E-GTS also has integrated main bearing caps.
Modern cast pistons can take a _lot_. Haven't heard of any issues with the G16E's pistons. The most common mod afaik is a high flow manifold catalytic converter (HJS w/ metallic substrate). I sort of don't feel the need to potentially introduce piston slap via forged & resp. slackier pistons.
Plenty of open deck turbo motors from BMW with only the typical rod bearing stuff to show for.
Old 08-09-24, 12:44 PM
  #74
Thanks, corrected.
Just decarbon them....
With what? The carbon is hard as a rock no solvent gets it off I've tried soaking the pistons for a MONTH (removed from engine) using various chemicals very little progress.
This isn't some holy grail nothing wrong with it but the strongest engine ever built in the 2JZ has no bearing girdle. Open deck is weaker no getting round it this is a compromise to increase cooling.
LeX2K is offline
Old 08-09-24, 02:25 PM
  #75
Thanks, corrected.
The 2JZ is weaker than a stock LT, LS, 5.0, Hemi, B58, S58, Viper, 5.2 FSI, GTR, etc etc etc......it's not a weak engine but it's nowhere near the strongest engine ever.
Quick Reply: Two GR Corollas Burned Down. Toyota Won’t Honor the Warranties
