Toyota's legendary V8 has a problem
#182
This is the engine I had in my 2006 Camry SE. Not very much power, but smooth. I sold it to my mechanic and he's driving it right now. Over 200k on it, only thing he had to do was change the gaskets due to a small oil leak on the manifold. Still has the original starter and alternator
#183
I really dislike whataboutisms that are not in fact equal, the 3MZ broken valve is a rare failure that will be fixed when you replace the valve. UR engine has an inherent flaw with the head design there is no fixing the flaw by replacing any parts.
#184
#185
Should have kept that car in the family. The 3MZ in my hybrid is fast, just as fast as most 2GR Toyota's. And it doesn't leak oil, no VVTi rattle, no premature water pump failures. I change oil every 3000-5000 miles this preserves gaskets and seals, again zero leaks after 250,000+ miles.
However that said I went away from Toyota in general when I realized how reliable other options are if you aren't an idiot owner
#186
Whats the flaw? The UR just seems sensitive to maintenance and the valley plate, I would ever want an MZ over UR engine if I could choose for sure!
#187
I hate that.
The alternatives however require you to be far more attentive/will punish you for doing stupid things like driving on a check engine light or known suspension issues. However they will basically work indefinitely if you follow their requirements
#188
No I meant there are engines that if you aren't stupid are perfectly able to get 500k miles but if you ARE stupid they will die before 100k. Toyotas are very resistant/designed for stupid/typical owners so they don't often have neglect related issues.
#189
#190
In 109k miles, my F-150's V8 has only needed a starter and a radiator hose o-ring. The starter went out around 70k. The o-ring maybe a year later. I've spent less than $400 on repairs. Everything else I've spent has been on regular maintenance(synthetic oil changes at 10k, coolant at 100k, brakes as needed, etc) or on repairing damage I've done to it on the trail.
#191
3MZ ain't better than the original UZ V8, come on guys. But it is a lovely engine, I agree.
Very smooth and refined, but no more so than a Honda V6 J-Series.
Nothing touched the UZ for smoothness and refinement, as refined as that 3MZ was.
#192
I would certainly rank it above a J series for many reasons, but the J is far more fun to drive
#193
Not nearly as much torque though as the Yota V6, I agree.
#194
I'm talking about reliability not refinement*, of course the 1UZ is smoother it's the perfect V8 engine. Small displacement, perfectly balanced. Lexus/Toyota missed a big opportunity they should have stuffed the 1UZ into a lightweight sports car. 86's and Nissan's with this engine are incredible to drive plus the 1UZ sounds terrific with a more open exhaust and intake.
* I never said the 3MZ was more reliable than the UZ.
#195
I thought you were talking about overall engine vs. engine. I'd have to give it to the Lexus V8, especially when it picked up VVT. But it's just opinion versus opinion..
